Old 01-07-2017, 07:13 PM   #1
Alaska Jim
Alaska Jim's Avatar
Default window garnish moldings
Can anyone tell me if there is a difference between the 1930-31 1/4 window moldings compared to the 1928-29 moldings? I also need to know if there is a difference between the rear window moldings. If there is a difference, how do you tell them apart? I have a project 30-31 coupe and all the inside window moldings are missing. It is also missing the one on the drivers door. any help would be appreciated . Thanks, ----Jim
Alaska Jim is offline   Reply With Quote
Old 01-07-2017, 08:18 PM   #2
Alaska Jim
Alaska Jim's Avatar
Default Re: window garnish moldings
forever4, thanks for the info, any way to tell which one is which, by looking at them? Thank you.---Jim
Old 01-08-2017, 09:57 PM   #3
SteveB31
SteveB31's Avatar
1928-1929 Coupe quarter window moldings are about 1 inch taller then the 1930-1931 ones, as is the glass. On a side note, the 1928-1929 ones are the same left and right and the 1930-1931 ones are different left and right.
Steve @ Bert's
SteveB31 is offline   Reply With Quote
Old 01-08-2017, 10:02 PM   #4
Alaska Jim
Alaska Jim's Avatar
SteveB31, Thank you for that information, it is very helpful.----Jim
