The Ford Barn
-   -   window garnish moldings (https://www.fordbarn.com/forum/showthread.php?t=212270)
Alaska Jim 01-07-2017 07:13 PM
Can anyone tell me if there is a difference between the 1930-31 1/4 window moldings compared to the 1928-29 moldings? I also need to know if there is a difference between the rear window moldings. If there is a difference, how do you tell them apart? I have a project 30-31 coupe and all the inside window moldings are missing. It is also missing the one on the drivers door. any help would be appreciated . Thanks, ----Jim
Alaska Jim 01-07-2017 08:18 PM
Re: window garnish moldings
forever4, thanks for the info, any way to tell which one is which, by looking at them? Thank you.---Jim
SteveB31 01-08-2017 09:57 PM
1928-1929 Coupe quarter window moldings are about 1 inch taller then the 1930-1931 ones, as is the glass. On a side note, the 1928-1929 ones are the same left and right and the 1930-1931 ones are different left and right.
Steve @ Bert's
Alaska Jim 01-08-2017 10:02 PM
SteveB31, Thank you for that information, it is very helpful.----Jim
