Old 01-03-2017, 11:08 AM   #1
Dollar Bill
Dollar Bill's Avatar
Default Need Advice Painting Curtain Pan 31 Roadster
I searched the archives but couldn't find a previous thread on how to adequately preserve the recessed area of the curtain storage compartment. Due to limited access and clearance, spray painting is out of the question. Am thinking brush/roller as the only option but would like to hear how others have tackled this project.
Would love to know how they painted this area on the assembly line - Thinking it must have been dipped before assembly.
I Love Anything That Turns Money Into Noise
Dollar Bill is offline   Reply With Quote
Old 01-03-2017, 11:46 AM   #2
C26Pinelake
Default Re: Need Advice Painting Curtain Pan 31 Roadster
A friend used a foam brush. Wayne
C26Pinelake is offline   Reply With Quote
Old 01-03-2017, 12:12 PM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
I would tape thin plastic over the surrounding area and spray paint it.
Old 01-03-2017, 12:26 PM   #4
3.6rs
3.6rs's Avatar
Originally Posted by Dollar Bill View Post
... Due to limited access and clearance, spray painting is out of the question. ...
I think, because limited acces and clearance, spray painting is the best solution.
3.6rs is offline   Reply With Quote
Old 01-03-2017, 12:47 PM   #5
C26Pinelake
I would think with limited access and clearance it would mean no spray paint. Wayne
Old 01-03-2017, 02:16 PM   #6
Dollar Bill
Thank you for the replies and I agree with spraying the open area directly beneath the seat bottom but the recessed area (pix 2 & 3) is only 2 inches high. Not sure how to get a paint gun or even a spray can in such a confined space.
Old 01-03-2017, 02:30 PM   #7
stouchton
stouchton's Avatar
How about one of those undercoating crevice attachments??
May not be pretty......
stouchton is offline   Reply With Quote
Old 01-03-2017, 02:32 PM   #8
C26Pinelake
Why are you insistant on spraying when in your opening statement you said it was out of the question??? Wayne
Old 01-03-2017, 02:45 PM   #9
3.6rs
3.6rs's Avatar
A spray can will be difficult but a spray gun can be set for mostly any paint job.
Old 01-03-2017, 02:46 PM   #10
Barber31
Barber31's Avatar
I've never thought of this till now but I wonder if a straw like in the WD40 fans will fit into a spray can nozzle? If it works maybe that would help in that 2 in area you're speaking of. I'm curious now if it will work so if I find a straw like that I'm gonna try it.
Barber31 is offline   Reply With Quote
Old 01-03-2017, 03:11 PM   #11
Tom Wesenberg
Many touch up guns or an air brush have a cup with a spout so you can spray in almost any direction by rotating the cup.
Old 01-03-2017, 04:28 PM   #12
Bob C
I've got a gun like Tom mentioned with the side cup and you can rotate the cup
so the gun is upside-down.
Bob
Old 01-04-2017, 04:10 PM   #13
Dollar Bill
I looked at previously mentioned touch up guns but still don't feel confident there is enough room to maneuver in such close quarters.
Thanks to everyone who responded.
Old 01-04-2017, 05:11 PM   #14
Tom Wesenberg
I wonder if you could use one of those sponge brushes to do the tight underside of the lip, then spray the pan so it all flows together?
Old 01-05-2017, 05:12 AM   #15
Dollar Bill
Thanks Tom, I'm sorta leaning in that direction. You can't see the recessed area without standing on your head or using a mirror so my major concern is strictly preservation.
Old 01-05-2017, 05:35 AM   #16
C26Pinelake
That was my suggestion in post # 2 Wayne
