Need Advice Painting Curtain Pan 31 Roadster 3 Attachment(s)
I searched the archives but couldn't find a previous thread on how to adequately preserve the recessed area of the curtain storage compartment. Due to limited access and clearance, spray painting is out of the question. Am thinking brush/roller as the only option but would like to hear how others have tackled this project.
Would love to know how they painted this area on the assembly line - Thinking it must have been dipped before assembly. |
Re: Need Advice Painting Curtain Pan 31 Roadster A friend used a foam brush. Wayne
Re: Need Advice Painting Curtain Pan 31 Roadster I would tape thin plastic over the surrounding area and spray paint it.
Re: Need Advice Painting Curtain Pan 31 Roadster Quote:
Re: Need Advice Painting Curtain Pan 31 Roadster Thank you for the replies and I agree with spraying the open area directly beneath the seat bottom but the recessed area (pix 2 & 3) is only 2 inches high. Not sure how to get a paint gun or even a spray can in such a confined space.
Re: Need Advice Painting Curtain Pan 31 Roadster How about one of those undercoating crevice attachments??
May not be pretty...... |
Re: Need Advice Painting Curtain Pan 31 Roadster I've never thought of this till now but I wonder if a straw like in the WD40 fans will fit into a spray can nozzle? If it works maybe that would help in that 2 in area you're speaking of. I'm curious now if it will work so if I find a straw like that I'm gonna try it.
Re: Need Advice Painting Curtain Pan 31 Roadster Many touch up guns or an air brush have a cup with a spout so you can spray in almost any direction by rotating the cup.
Re: Need Advice Painting Curtain Pan 31 Roadster 1 Attachment(s)
I've got a gun like Tom mentioned with the side cup and you can rotate the cup
so the gun is upside-down. Bob |
Re: Need Advice Painting Curtain Pan 31 Roadster I looked at previously mentioned touch up guns but still don't feel confident there is enough room to maneuver in such close quarters.
Thanks to everyone who responded. |
