Old 12-20-2016, 05:32 PM   #1
Nabco
Nabco's Avatar
Default Air Filter (just a question not trying to start a debate)
So what do you guys think about an air filter like this, I know it's not historically correct but definitely is out of the way if everything.
1930 Deluxe Coupe
"Sister"
Nabco is offline   Reply With Quote
Old 12-20-2016, 09:20 PM   #2
Jim/GA
Jim/GA's Avatar
Default Re: Air Filter (just a question not trying to start a debate)
Without something to compare this filter to for scale, it is impossible to tell exactly how big it is. My gut feel, without hard data to back it up, is that the filter element area is too small for our cars. If it restricts the flow of air, on a stock Model A Zenith carburetor, it will make the engine run rich.
Jim Cannon
"Have a Model A day!"
Old 12-20-2016, 10:01 PM   #3
Nabco
Nabco's Avatar
Thanks Jim,
That's what I'm not sure of either, I've been running her with no filter at all but thought this could be a good alternative when a filter is needed.....I'm pretty sure these are actually made for motorcycles.
Nick
1930 Deluxe Coupe
"Sister"
Old 12-20-2016, 10:02 PM   #4
mhsprecher
mhsprecher's Avatar
Here is what I use. More filter area than an Air Maze. http://www.ebay.com/itm/Ford-Model-A...uretLw&vxp=mtr
Here is another approach: http://www.model-a.org/filtering_air_into_carb.html
mhsprecher is offline   Reply With Quote
Old 12-20-2016, 10:04 PM   #5
DaWizard
Send a message via AIM to DaWizard
Funny, unless you are driving on dirt or gravel roads, it ain't needed!
Didn't come with the car and that was ALL dirt and gravel roads back then.
DaWizard is offline   Reply With Quote
Old 12-20-2016, 10:09 PM   #6
Aok
Aok's Avatar
I use the air maze with replaceable filters and do not find it in my way. Not a show car just a driver.
Aok is offline   Reply With Quote
Old 12-20-2016, 10:11 PM   #7
C26Pinelake
I totally agree! Wayne
C26Pinelake is offline   Reply With Quote
Old 12-20-2016, 10:27 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Just curious. If I don't need my air filter why does it keep getting dirty so I have to clean it. It MUST be filtering SOMETHING...
Old 12-20-2016, 10:37 PM   #9
DaWizard
You are in So Cal, we know it is smog it's filtering.
Ya know, I am pretty sure not one Model A rolled off the assembly line with an air filter.
Old 12-20-2016, 10:53 PM   #10
hewe
Ever run a marathon with a rag in your mouth.
hewe is offline   Reply With Quote
Old 12-20-2016, 10:58 PM   #11
Nabco
Nabco's Avatar
I'm actually on team "no filter" I'm a newbie to A's and have minimal mechanical skills at best, I've tried the high boy, the one that hangs down by the manifold and the one that curls under the carb and I can tell that she runs way better with no filter.
The purpose of starting the thread was to see if anyone has tried this type filter. I did order one $8.50 to put in th carb over the winter for rodent deterrent, right now I have it covered with duct tape and thought this would be easier if I wanted to run the car over the winter.
As always thanks for the replies.
1930 Deluxe Coupe
"Sister"
Old 12-20-2016, 11:04 PM   #12
Y-Blockhead
I'm pretty sure they didn't have alternators or electric water pumps either...
Old 12-20-2016, 11:09 PM   #13
iverson
iverson's Avatar
my uncle always said if you can breath the air with out a filter your car can too!
iverson is offline   Reply With Quote
Old 12-20-2016, 11:19 PM   #14
DaWizard
Heh, mine don't need an air filter, it craves the smog.
Old 12-21-2016, 12:18 AM   #15
H. L. Chauvin
FWIW; Humble Opinion On Starting A Logical Debate on Filtering Air:
Installing a recommended Model A Large K & N Hi-Boy Air Filter in 2016, and installing specified air filters in Modern cars are like logical females installing today's female sanitary Tampons in 2016.
Please remember, in some cases, in 2016, we will always have to live with some nasty jerks who omit same, live with the consequences, and these cheap people really just don't give a damn.
Long live your "well used" Model A engine with an air filter.
H. L. Chauvin is offline   Reply With Quote
Old 12-21-2016, 12:49 AM   #16
ian Simpson
My motorcycles never had a filter. They usually needed rebuilding due to cylinder wear before running 25,000 miles even though they never left paved roads and had oil changes at least every 1,000 miles. Also, two of them had efficient oil filtration.
My 1988 Dodge Caravan, 2000 Dodge Durango and 2006 Dodge Dakota (I like Dodge vehicles, OK?) exceeded 200,000 miles without any attention except for filter and oil changes. They have very efficient filters - I am convinced.
ian Simpson is offline   Reply With Quote
Old 12-21-2016, 06:15 AM   #17
mhsprecher
mhsprecher's Avatar
My point is that all manufacturers started putting air filters on their cars in the 1930's. What changed? I suspect it was because they all realized it was beneficial for the operation and life of the car. Both of my A's have the K&N Highboy filter and run great, certainly better than the Air Mazes they had when I bought them.
Old 12-21-2016, 06:30 AM   #18
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Without an air filter, run your finger in the air horn & feel the GRIT!!!!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 12-21-2016, 06:38 AM   #19
3.6rs
3.6rs's Avatar
Very expensive for an air filter.
3.6rs is offline   Reply With Quote
Old 12-21-2016, 07:39 AM   #20
Mitch//pa
When you posted your question to find out only about that particular air filter the debate began..did u expect a different outcome
