Old 11-02-2016, 04:32 PM   #1
COOTER
Default Cam Gear Removal
I have the Double D tool to remove the nut and I've blocked the gears with a piece of wood but the gear just keeps losing teeth as I spin it. Any suggestions on getting this thing off?
COOTER is offline   Reply With Quote
Old 11-02-2016, 04:49 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Cam Gear Removal
Impact wrench
www.whidbeymodelaclub.com
Old 11-02-2016, 04:56 PM   #3
COOTER
Looks like I'll be removing the radiator. Was hoping to avoid doing that. Damn.
Old 11-02-2016, 05:26 PM   #4
Patrick L.
Patrick L.'s Avatar
Rather than a block of wood, try a shop rag.
Old 11-02-2016, 05:47 PM   #5
john charlton
john charlton's Avatar
The block of wood is a no no .Do as Patrick says use the wifes best heavy towel and stuff it in ,spreads the load on the teeth ( as the actress said to the bishop )
John in cool dark roll on sunny Chandler AZ Suffolk County England
Old 11-02-2016, 08:46 PM   #6
larrys40
I concur with the impact guys. I have had them so tight it stripped of all the teeth and I had to put a pipe wrench on the hub ( old cloyes gear with aluminum hub. Of course I had to remove the oil pan and do a clean out.
As Forever 4 indicated use a good 1/2 impact and give it some bumps, hopefully it will loosen up.
When re-installing make sure your timing marks are aligned. and spring and plunger re-installed
larrys40 is offline   Reply With Quote
Old 11-02-2016, 08:56 PM   #7
Mitch//pa
Lefty loosie,, righty tightie
Old 11-02-2016, 09:59 PM   #8
larrys40
Mitch... yes you make us laugh! Your humor most definitely appreciated!
Larry
Old 11-03-2016, 05:46 AM   #9
Patrick L.
Patrick L.'s Avatar
Isn't that only when you're north of the equator ?
Old 11-03-2016, 10:19 AM   #10
Jim Brierley
Before pulling the rad, you might trying vice grips on the cam gear, resting them against the pan to keep from turning. Impact wrench will definitely work.
Old 11-03-2016, 10:20 AM   #11
katy
katy's Avatar
Hammer and flat ended punch.
Old 11-06-2016, 05:07 PM   #12
COOTER
Impact was the answer. Thx.
