Old 08-04-2016, 10:47 PM   #1
hb32
hb32's Avatar
Default 59A fan belt info
Looking for a p/n for a 59A fan belt. 59A mounted in a 32 frame with original mounts and a gen drive fan.
Crank pulley is an original 59A piece with the front sheave removed and pumps are 59A style with all pulleys wide belt.
hb32 is offline   Reply With Quote
Old 08-04-2016, 11:04 PM   #2
flatheadmurre
flatheadmurre's Avatar
Default Re: 59A fan belt info
A generic B52 belt should work.
Old 08-05-2016, 06:10 AM   #3
Kerk
I have used a B54 with some success.kx
Kerk is offline   Reply With Quote
Old 08-05-2016, 11:51 AM   #4
rotorwrench
rotorwrench's Avatar
If you are using original 32 mounts, what is your plan for the water pumps? are you going to trim the mounting ears off or leave them on?
Old 08-05-2016, 12:08 PM   #5
hb32
hb32's Avatar
I trimmed the mounts off before installing the pumps.
Not a great pic but it works.
Old 08-05-2016, 12:34 PM   #6
Bruce Lancaster
There's one more variable, the height of the generator mount stud from the block surface to its place on the manifold. A pure 59A with original '46-8 manifold would use a somewhat longer belt than a 59A with a '37 manifold, for instance. Ford varied this dimension in different applications and aftermarket manifolds also vary.
Old 08-05-2016, 12:47 PM   #7
hb32
hb32's Avatar
Thanks for your input Bruce and another variable to factor into the equation.
I am using an original Edelbrock Regular intake so will have to do some measuring.
Stud is 1.750" center off the surface of the block.
