59A fan belt info Looking for a p/n for a 59A fan belt. 59A mounted in a 32 frame with original mounts and a gen drive fan.
Crank pulley is an original 59A piece with the front sheave removed and pumps are 59A style with all pulleys wide belt. |
Re: 59A fan belt info A generic B52 belt should work.
Re: 59A fan belt info I have used a B54 with some success.kx
Re: 59A fan belt info If you are using original 32 mounts, what is your plan for the water pumps? are you going to trim the mounting ears off or leave them on?
Re: 59A fan belt info Quote:
Not a great pic but it works. http://i765.photobucket.com/albums/x...sxgipg7ed.jpeg |
Re: 59A fan belt info There's one more variable, the height of the generator mount stud from the block surface to its place on the manifold. A pure 59A with original '46-8 manifold would use a somewhat longer belt than a 59A with a '37 manifold, for instance. Ford varied this dimension in different applications and aftermarket manifolds also vary.
I am using an original Edelbrock Regular intake so will have to do some measuring. Stud is 1.750" center off the surface of the block. |
