#28 |
Don't put a bolt into that 1/8" pipe plug hole! It's a pipe thread and a standard bolt will mess up the threads. When I have to hold the pump in position when installing the pan, I use a Phillips head screwdriver or a drift punch wedged throguh the hole and between the frame and the pump.
Ray Horton, Portland, OR As you go through life, keep your eye on the donut, not the hole. ![]() |
