Old 06-12-2016, 08:38 AM   #26
old31
Default Re: 31 Deluxe Roadster too much oil, should I drain some?
Originally Posted by Tom Wesenberg View Post
No bolt holds the pump in place. The spring at the bottom of the pump holds it until you lower the pan. Make sure the spring doesn't have any rust pits, or it might snap while in use.
The side of the block should have a 1/8" pipe plug with a screwdriver slot.
Isn't this bolt used to hold up the oil pump? I was able to remove the bolts on the bottom of the pump and removed and cleaned the pump screen, and the oil pump remained up.
old31 is online now   Reply With Quote
