Old 02-25-2016, 12:40 PM   #1
Mark's 37
Mark's 37's Avatar
Default Fuel sender float cork saturated
I need to replace the fuel sender float on the 37 Ford. I has what appears to be the original cork float that all the varnish has melted away and is now saturated with fuel. C and G offer two floats for these cars that are brass. Which, if any, of these will fit my sender and how are they attached? Thanks.
Mark's 37 is offline   Reply With Quote
Old 02-25-2016, 12:49 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Fuel sender float cork saturated
I had the same problem with my '37 and replaced the cork float with two of these >
http://www.snydersantiqueauto.com/gauge-float-only
Old 02-25-2016, 01:18 PM   #3
Mark's 37
Mark's 37's Avatar
Thanks. A local early Ford parts place, All Ford Parts, has them and have two on the way. The sender works fine just needs the float.
Old 02-25-2016, 01:40 PM   #4
petehoovie
petehoovie's Avatar
BTW - I epoxied the two together and sprayed them with clear, fuel-proof, model airplane dope....
Photo shows the removed original cork float and the newly installed replacement float....
Old 02-25-2016, 01:50 PM   #5
Kurt in NJ
Kurt in NJ's Avatar
I used a modern car float salvaged from a replaced fuel pump assembly--- look in the trash at most any garage
Kurt in NJ is online now   Reply With Quote
Old 02-25-2016, 02:00 PM   #6
39topless
Old carb floats work great.
39topless is offline   Reply With Quote
Old 02-25-2016, 02:20 PM   #7
Mark's 37
Mark's 37's Avatar
How did you attach them to "shepherds hook" end of the sender?
Old 02-25-2016, 02:27 PM   #8
petehoovie
petehoovie's Avatar
I coated the so called "shepherds hook" with epoxy and worked the float on to it. Works like a champ....
Old 02-25-2016, 02:46 PM   #9
Mark's 37
Mark's 37's Avatar
I was referring to using the metal carb or other used sender floats instead of the Model A floats.
Old 02-25-2016, 03:09 PM   #10
petehoovie
petehoovie's Avatar
They can't be used in our application. They require a 'hook' on the sender arm. This is why I did what I did....
Old 02-25-2016, 03:38 PM   #11
Mark's 37
Mark's 37's Avatar
I am going to do it the way you did yours. Seems pretty straight forward and simple. I was just curious how someone could attach a carb float to the sender.
Old 02-25-2016, 05:02 PM   #12
cmbrucew
cmbrucew's Avatar
Solder will work on a brass float.
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 02-25-2016, 05:08 PM   #13
petehoovie
petehoovie's Avatar
Bruce
The arm is steel though. Cold solder joints. Too much of a hassle....
Old 02-25-2016, 05:26 PM   #14
Charlie ny
M 37,
A 94 carb float works quite perfectly....just solder it on the hook.
Charlie ny
Old 02-25-2016, 11:12 PM   #15
Drbrown
Drbrown's Avatar
The OE cork float on my '47 sender was saturated. Sender works fine. I had a Drake sending unit kit with a hollow poly-float bulb. It snapped right-in-place in the loop of the original wire arm of the old cork float.
Drbrown is offline   Reply With Quote
Old 02-26-2016, 12:37 AM   #16
petehoovie
petehoovie's Avatar
Look at the picture Mark posted of his sending unit above. There is no 'hook' on it like yours....
