Old 10-27-2015, 11:55 PM   #1
gbruce1949
Default clutch pedal
after replacing my clutch and putting my engine back in there is a spring that goes from the back of oil pan which holds the clutch pedal with tension so it sits even with brake pedal.......I can't figure where the other end of long spring connects to clutch pedal or assembly?
gbruce1949 is offline   Reply With Quote
