Old 10-22-2015, 08:49 PM   #18
Timsalways
Timsalways's Avatar
Default Re: How did this work? upside down brake actuation arm?
Originally Posted by Tom Wesenberg View Post
Yes, see #4. I would leave the backing plates in place and change the brake arm and flip the cam as I said in #4.
Also remove the parking brake arm and install the spring if it's not there. There is a right and left, so don't mix them up.
Be sure to notice the slight slant for the brake arm clevice, so the rods run parallel with the frame.
BINGO! I think you nailed it Tom, I thought those rods were straight, I got to get back under there and check it out, I haven't done anything for a few days now. I may run it for a awile before getting it 100% right, this is the first time I took rear hub off. "It's all used parts" are those pins easy to work, I have never peened a pin.
Timsalways is offline   Reply With Quote
