How did this work? upside down brake actuation arm? 2 Attachment(s)
Hi, have put more miles on my 1930 Tudor model A this year than my 2004 Avalanche. I am always trying to get rid of rattles! While while replacing the brake rod's and installing anti-rattlers I have find many errors. My brakes have always been great! But I was having a major problem with the installation with the anti rattlers. Nothing lined up correctly. Are these upside down? and how did this configuration work for so long? I am getting ready to pull the drum/hub off. or can I just flip these around? I have had no problem braking but I am sure these are installed wrong. Any help or pictures will be appreciated. I hope to attach a picture or two. thanks Tim
Re: How did this work? upside down brake actuation arm? I've never seen that before. :eek: Those are definitely upside down!
Re: How did this work? upside down brake actuation arm? It looks to me like someone installed the backing plates on the wrong side of the car, then modified the brake rods to match.
Re: How did this work? upside down brake actuation arm? I would take the drums off and check out the complete service and parking brake assemblies. At the very least the brake cams will need to be changed (flipped) when the arms are installed correctly. The cams will need to be flipped so they spread the shoes when the arm is pulled forward.
Also be sure the arms are on the correct sides. The opening for the rod is angled to match the frame taper. |
Re: How did this work? upside down brake actuation arm? People sure do some amazing things. I have never seen this before also.
When you buy a Model A you never know what you will get. |
Re: How did this work? upside down brake actuation arm? [QUOTE=George Miller;1175474]People sure do some amazing things. I have never seen this before also.
When you buy a Model A you never know what you will get.[/QUOTE It's EASY to forget things, how often do you look at some detail & say, "I DON'T REMEMBER IT LOOKIN' QUITE LIKE THAT"!!:confused::confused::confused: PICS are a great REMEMBERRRRER TOOL:D Bill W. |
Re: How did this work? upside down brake actuation arm? Quote:
Re: How did this work? upside down brake actuation arm? Am I missing something???? I do not see the emergency brake actuating arm or brake rod!!!!
Re: How did this work? upside down brake actuation arm? 1 Attachment(s)
Here is a photo showing the correct installation of the service and emergency brake rods and actuating arms.
Re: How did this work? upside down brake actuation arm? 2 Attachment(s)
There is definitely a spring on the e-brake. There are a couple things about them:
• There is a right and a left spring • They are a B***h to put on. I got this little tool at HF, does make things a bit easier. |
Re: How did this work? upside down brake actuation arm? IMO isn't the brake arm installed upside down,your adjuster sould be on the back side
Looking at 160b's picture maybe just changing the brake arm will make it right |
Couldn't you turn the lever up and turn the cam around ? Bob |
Re: How did this work? upside down brake actuation arm? Both arms ( e- brake & service brake ) should be nestled together like in 160B's picture
Both arms are pulled foreword to engage |
Also remove the parking brake arm and install the spring if it's not there. There is a right and left, so don't mix them up. Be sure to notice the slight slant for the brake arm clevice, so the rods run parallel with the frame. |
Re: How did this work? upside down brake actuation arm? I missed that Tom.
Bob |
Soo out to the pile of parts in the shed found a good drivers side and blasted and restored it!:cool: |
Re: How did this work? upside down brake actuation arm? I have seen that several times. You will have to take it apart some to fix it, but really just move the arms upright and reverse the cams. But........I would take it all apart as you don't know what else might be wrong.
Re: How did this work? upside down brake actuation arm? Sorry----------- Tom,George,Bill ------- your replies won't there when I posted
