Old 10-11-2015, 08:50 PM   #1
Steve Plucker
Default ORIGINAL Sprayed Body Deadner
Does anyone have an original Roadster or Coupe showing the sprayed-on Body Deadener that was used on the quarter panels? Would like a photo if possible for Part 3 of the Rumble Seat to Trunk Conversion article.
Pluckl
Old 10-11-2015, 10:47 PM   #2
P.S.
Default Re: ORIGINAL Sprayed Body Deadner
Is it the same tar-like deadener sprayed on the inside of the Fordor panels? If so, I can send you a pic. from an unrestored Fordor.
P.S. is offline   Reply With Quote
Old 10-12-2015, 06:10 AM   #3
Flop
I've never seen anything in the quarters ... Only the doors .
Please call or email while website is down!
412 867 1659
[email protected]
https://www.facebook.com/flop.custom
Flop is offline   Reply With Quote
Old 10-12-2015, 07:13 AM   #4
Keith True
Keith True's Avatar
I have a June of 30 Standard Roadster,unmolested,35,000 mile car.The quarters are bare,just original overspray from the body color paint.
Old 10-12-2015, 07:13 AM   #5
Steve Plucker
Yes, it is the same stuff.
Pluck
Old 10-12-2015, 07:15 AM   #6
Steve Plucker
It might be to that some plants did not use the stuff...I to have seen it both ways. It was on my September 1929 Coupe.
Pluck
Old 10-12-2015, 09:45 AM   #7
P.S.
Pluck
OK, then I can help.
As mentioned above, I haven't seen it in the quarter panels on any of the roadsters, but I do have it in the quarter panels of my Briggs Fordor. They also applied it to the doors and the rear panels right up to the window line.
Old 10-12-2015, 11:24 AM   #8
Bob Bidonde
Bob Bidonde's Avatar
My 1931 Coupe has it on the doors only. There is none in my Victoria.
Bob Bidonde
Old 10-12-2015, 11:30 AM   #9
TinCup
TinCup's Avatar
Same as Bob only had it on the coupe doors.
TinCup is offline   Reply With Quote
Old 10-12-2015, 08:44 PM   #10
Tinbasher
Tinbasher's Avatar
Yes it was called 'Body Shultz". You could buy it from the Auto Body Jobbers and the 1 Qt. tin would screw onto a syphon type gun. Basically a Air blow gun with a pickup tube off of the bottom of it. The lower the air pressure you used the heavier the texture of the sound deadener would be. After about 48 hours it would set up and the surface would be dry to the touch. The closest thing to it now is black rockerpanel coating. It's now in a spray bomb but the texture is not as coarse.
John Poole "The Old Tinbasher"
Tinbasher is offline   Reply With Quote
Old 10-13-2015, 12:25 AM   #11
RandyinUtah
My November 1930 Murray town Sedan had no sound deadener in the doors.
RandyinUtah is offline   Reply With Quote
Old 10-16-2015, 12:42 AM   #12
Mike V. Florida
Mike V. Florida's Avatar
We have it in the late 31 vicky doors.
Old 10-16-2015, 11:06 AM   #13
P.S.
Sorry for the delay, Steve. Here you go. Close up also.
Old 10-16-2015, 12:20 PM   #14
Kevin in NJ
BTW, If you want the original type you will need to add natural mineral fibers. Or so I believe.
I have noticed little white fibers in the stuff when sandblasting the doors.
