Old 09-11-2015, 07:49 AM   #1
Vin-tin
Vin-tin's Avatar
Default I saved a few more
Figured I'd post some pictures of some original parts I saved instead of buying repro junk.
First up is my coupe's battery holder. The bottom plate was almost totally gone, so I cleaned it up and welded a new bottom plate to it. Also, the threads on the one hold-down stud were stripped, so I cut the bad part off and made a replacement.
1929 Coupe
1930 Coupe
1935 Ford 5 window coupe
Vin-tin is offline   Reply With Quote
Old 09-11-2015, 08:08 AM   #2
Vin-tin
Vin-tin's Avatar
Default Re: I saved a few more
Next up are my brake rods.
Most of my coupe's brake rods needed some kind of work. Some were bent pretty bad. Some had worn areas. The return springs had "eaten" away the metal, and the clevis pins had the holes worn oversize. I welded-up the low spots. Also used a copper rod to fill the holes so the weld wouldn't stick. I installed steel bushings in some of the more severely worn holes.
Follow the pictures. They show the before and after.
I tried to keep as many of the original characteristics as I could.
1929 Coupe
1930 Coupe
Old 09-11-2015, 08:22 AM   #3
Ray in La Mesa
Kool! I always try to save original parts too,just to see if I can, nothing ventured, nothing gained. At the San Diego Auto Museum restoration shop, I tackled the bottom panel of a 1929 Erskine radiator shell, It was 90% gone and the 10% was lace. With a torch, brazing rod and a good detailed photo I proceeded to braze "on air" for 2-3 days to see if I could save it as a replacement was not available. Two pounds of brazing rod later and a LOT of grinding we had a playable shell-though very expensive! It would have been easier to braze in a patch panel but I wanted to see if I could do it.
Ray in La Mesa is offline   Reply With Quote
Old 09-11-2015, 08:46 AM   #4
Hoogah
Hoogah's Avatar
I like your handy work, Ray and Vin-Tin. Wish I had your skills.
Hoogah is offline   Reply With Quote
Old 09-11-2015, 09:18 AM   #5
2manycars
2manycars's Avatar
Nice work repairing the brake rods. The one with the wear at the anti=rattler was dangerously worn, to where it might have broken under sever pedal pressure.
2manycars is offline   Reply With Quote
Old 09-11-2015, 12:26 PM   #6
Vin-tin
Vin-tin's Avatar
Hoogah, anyone can do this. It's not hard. You just have to believe in yourself and have patience.
I feel the same way as Ray. If I try and fail, so what. Nothing lost except my time.
1929 Coupe
1930 Coupe
Old 09-11-2015, 01:16 PM   #7
Tom Wesenberg
Tom Wesenberg's Avatar
Nice save.
The first picture shows what happens when the antirattlers don't have good spring pressure to keep the upset in the pocket.
Old 09-11-2015, 01:28 PM   #8
mhsprecher
mhsprecher's Avatar
Good work. We need to be careful about parts that are crucial to safety, like brake rods. It had not broken and hopefully it is stronger than before, but that would be my only concern.
I am often the patron said of hopeless items of many kinds, so I am all about salvage and repair, if we can.
mhsprecher is offline   Reply With Quote
Old 09-11-2015, 03:24 PM   #9
C26Pinelake
Great effort on your part! Keep up the great work. Wayne
C26Pinelake is offline   Reply With Quote
Old 09-12-2015, 12:07 AM   #10
Drive Shaft Dave
I liked the way you saved the batterey tray.
Drive Shaft Dave is offline   Reply With Quote
Old 09-12-2015, 04:53 AM   #11
Wick
Wick's Avatar
Front motor mount bolt is a easy fix also.
Wick is offline   Reply With Quote
Old 09-12-2015, 10:29 PM   #12
Mike V. Florida
Mike V. Florida's Avatar
Way to go!
Old 09-13-2015, 09:20 AM   #13
cp5491r
cp5491r's Avatar
Nice work.
cp5491r is offline   Reply With Quote
