Old 06-17-2015, 09:08 PM   #1
LopezCarguy
LopezCarguy's Avatar
Default Shocks
Do shocks have same resistance up and down, in other words does shock dampen more on up stroke or down stroke??
The only thing worth learning is what you learn after you know it all !!
LopezCarguy is offline   Reply With Quote
Old 06-17-2015, 09:36 PM   #2
RHD
RHD's Avatar
Default Re: Shocks
Hi LopezCarguy.
The original type Houdaille shocks from new would have 10% in one direction (the downward stroke) and 90% the other.
I have tested NOS shocks and found them close to 5/95. Today if you can get a shock to perform at around 25/75 you are doing well. Many of the professionally restored shocks only obtain this resistance.
Best of luck.
Cheers,
Les.
R.H.D.
Silence is golden unless you have kids, then silence is suspicious.
RHD is offline   Reply With Quote
Old 06-18-2015, 04:50 AM   #3
updraught
updraught's Avatar
Default Re: Shocks
Depends on whether you want a "performance" ride or a smooth ride. "Performance" shocks tend to be stiff in both directions for handling (at the expense of ride).
A "Koni Special D" shock, for example, has almost no resistance on compression (going over a bump), and the rebound is adjustable to "heaps" of resistance.
It is good for controlling a stiff spring as it allows it to compress quickly on a bump. The rebound resistance can then control the rebound (expansion) of the spring to create a smooth ride.
If you adjust the Koni up too much the wheels won't come down fast enough after a bump, and you will feel them leave the road. This is not good and it is then time to back them off a bit ...
updraught is offline   Reply With Quote
Old 06-18-2015, 08:24 AM   #4
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Shocks
Moving the shock arm up should have much less resistance than moving it down----when I was rebuilding shocks for my car I found that with the adjusting valve closed the 2 foot handle would still move up, but could feel like it was stuck moving the lever down---then I opened the needle valve so it took about 60 seconds to move with about 50 lbs on the handle----there is an article in the model A service bulletins about rebuilding and setting shocks---the 50lbs and 2 foot lever was my interpetation of the tool in the service bulletins
Old 06-18-2015, 09:17 AM   #5
fiddlybits
fiddlybits's Avatar
Default Re: Shocks
Now that everyone has explained how to build the clock in answer to the question "what time is it?"......
No, they do not have the same resistance up and down.
For more information.... see previous posts.
fiddlybits is offline   Reply With Quote
Old 06-18-2015, 10:57 AM   #6
ericr
ericr's Avatar
Default Re: Shocks
perhaps I mis-read it but two posts are contradictory as to what stroke requires greater resistance....
ericr is offline   Reply With Quote
Old 06-18-2015, 07:18 PM   #7
updraught
updraught's Avatar
Default Re: Shocks
Hey Les,
All my A shocks are like house bricks!
Is this 10% of full resistance on the downward (rebound) stroke?
Old 06-18-2015, 08:01 PM   #8
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Shocks
When you hit the bump and compress the spring you want the shock to let it move easy --to absorb the bump---after the bump the shock has to slow the rebound of the spring so you don't bounce
Old 06-18-2015, 11:07 PM   #9
Mike V. Florida
Mike V. Florida's Avatar
Default Re: Shocks
Originally Posted by RHD View Post
Hi LopezCarguy.
Best of luck.
Cheers,
Les.
This is the guy that literally wrote the book on Houdallie shocks.
Old 06-18-2015, 11:13 PM   #10
Tudortomnz
Tudortomnz's Avatar
Default Re: Shocks
If you want to know about & work on original Houdaille shocks, Les Pearsons book is invaluable.
Tudortomnz is offline   Reply With Quote
