Been trying to put chrome acorns on my head bolts, and I'm having a heck of a time. They are all going on difficult, no foil needed, but some are splitting, and there's one bolt in particular that I've destroyed two acorn nuts on.
I'm using a piece of UHMV as to not dent the nuts. Is there any easy way to do this? |
are you sure you have the correct size acorn nuts they should be 11/16 but they come in 5/8 9/16 as well. try them on a 5/8 bolt and see
My head bolts are new 11/16" from Van Pelts. Nuts must be same cause I tried them on a 5/8" bolt, way too loose.
Chrome acorn Nuts are from Speedway. |
Interested to see your solution, because the ones that I got from Speedway are too tight to fit without the use of semi-destructive install methods.
HotRodHundred.com Reliability Runs It's about the drive!!! StreetRodder.Net The FUN is in the RUN!!! |
how about using covers.
I destroyed a Speedway set. I bought a set from another supplier and they were perfect. I hold them on with a dab of silicone.
i just use a bit of electrical tape to cover the stud and overlap a little bit and they snug right up and stay on and are easy to pop off.
i meant cover the stud bold nut (early v8).
I'm not having a problem with them falling off, but going on the first place.
Bassman, do you remember where you got them from? Last edited by Ralph Moore; 05-31-2015 at 11:51 PM. |
PITA, but I took a dremel tool and carved them out a bit( still tough going on),
Gee I only have 24 more to go ![]() I would like a source for some proper fitting ones though, then I can take all these to the firing range and have fun with my .22! |
I just gave them a tweak from one side too the other with a set of "nut F**Kers" (multi grips) on the open end. This hardly marks them. Now they're tight enough to stay on but easy enough to pull off if you have to.
GB
"you can't make honey out of dog sh*t" "You're a long time looking at the lid" |
#13 |
#14 |
I didn't like mine, gave away a whole bag. I prefer the stock original look on the whole car.....36 Fordoor.
Tim Carlig |
#15 | |
http://www.ebay.com/itm/Flathead-for...item43dd4a3864 |
#16 |
The ones that came with my ARP studs work perfectly and are deep enough they don't bottom out. These are not caps but actual acorn nuts.
#17 | |
#18 |
Speedway nut covers are plastic and do not work very well. Buy a set of chrome steel nut covers from Bob Drake and you will be happy.
#19 |
Update in the acorns. My Speedway ones were metal, but fit was terrible.
Took ZZLegend and flatheadmurre's advice and ordered from Offyonline. Worked great! Tiny bit of silicone, and I did one side in about five minutes! Now I wish I had ordered his intake set. |
#20 |
Another quality speedway product......i quit buying ANYTHING that is speedway brand they make nothing but crap....i try not to buy from them period..but to each his own
