Old 02-15-2015, 04:42 PM   #1
Steve Plucker
Default Best adjustable lifters for Model A
What are the best adjustable lifters, brand wise, that you have found for use in the Model A Ford engine and WHY?
Thanks.
Pluck
Old 02-15-2015, 05:30 PM   #2
kevinmac/toledo
Default Re: Best adjustable lifters for Model A
Thanks.
Pluck
steve; i like the hollow lifters ,to reduce the weight of valve train components. racing has taught us the accelerated wear with heavy components. i think this also helps with longevity....kev....brand of your choosing..
kevinmac/toledo is offline   Reply With Quote
Old 02-15-2015, 06:40 PM   #3
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
The best tappets are manufactured by Colony, ...and are sold thru retailers.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-16-2015, 12:03 AM   #4
SteveB31
SteveB31's Avatar
Colony lifters are the best, but two of the larger vendors make their own lifters now, and they are NOT good lifters. Ask for Colony , and don't settle for any others.
SteveB31 is offline   Reply With Quote
Old 02-16-2015, 07:04 AM   #5
Bruce of MN
Bruce of MN's Avatar
Which retailers carry them?
Old 02-16-2015, 11:33 AM   #6
john in illinois
john in illinois's Avatar
Steve B31 owns Bert's so he probably sells them.
John
john in illinois is offline   Reply With Quote
Old 02-16-2015, 12:01 PM   #7
wrndln
The Colony double nut lifters I tried to use had the base that was too small compared to the other lifters - single nut I believe. Vince Falter has a good section about repro lifters on his website - link below. He isn't impressed with the small base on Colony double nut lifters. I tried to adjust the double nut lifters and it was a real task as the part on the lifter base below the double nuts was below the lifter housing in the block. I suppose you could cut off the top of the lifter housing, but I don't want to hack up the block to fix a problem that shouldn't be happening.
Rusty Nelson
http://www.fordgarage.com/pages/valv...comparison.htm
Old 02-16-2015, 12:22 PM   #8
Jim Brierley
A large foot is necessary. I get mine from Arizona Model A, 480-782-0266.
Old 02-16-2015, 01:49 PM   #9
Pete
You need to know what the cam you are running was ground for.
1 inch diameter lifters or 1.1 inch diameter.
Stock original cams require the 1.1.
Old 02-16-2015, 03:14 PM   #10
BRENT in 10-uh-C
Yes very true, and not all info we read is 110% accurate.
BRENT in 10-uh-C
Old 02-16-2015, 04:12 PM   #11
CarlG
CarlG's Avatar
OK, so I have a Stipe IB330 cam. What diameter lifter should I have?
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 02-16-2015, 04:32 PM   #12
Pete
Originally Posted by carlg View Post
ok, so i have a stipe ib330 cam. What diameter lifter should i have?
1.1
Old 02-16-2015, 06:16 PM   #13
CarlG
CarlG's Avatar
Thanks Pete, I'll get the yardstick out when I get home.
Alaskan A's
Old 02-16-2015, 06:25 PM   #14
Patrick L.
Patrick L.'s Avatar
My intention is not to highjack this thread, but, does anyone still use originals ? Or, am I the only one that likes them ?
Old 02-16-2015, 08:02 PM   #15
Pete
I make my own but they are NOT adjustable. (I do circle track race engines only)
Other than race applications on a model A/B engine, there isn't enough weight difference to use original type lifters.
Old 02-16-2015, 08:04 PM   #16
Tom Wesenberg
Tom Wesenberg's Avatar
I plan to keep my originals.
Old 02-16-2015, 08:09 PM   #17
Pete
I haven't seen an original lifter for a long time. Aren't they 1 inch dia.?
Old 02-16-2015, 08:19 PM   #18
d.j. moordigian
d.j. moordigian's Avatar
The originals are 1,125",....I believe there 2 styles of "mushroom" heads.
Thick and thin, depending on which Model A block you have..
d.j. moordigian is offline   Reply With Quote
Old 02-16-2015, 08:48 PM   #19
Rowdy
The only originals I use are the B lifters, but I make them adjustable. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 02-16-2015, 08:50 PM   #20
Marco Tahtaras
Marco Tahtaras's Avatar
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
