The Ford Barn
-   -   Best adjustable lifters for Model A (https://www.fordbarn.com/forum/showthread.php?t=161561)
Steve Plucker 02-15-2015 04:42 PM
What are the best adjustable lifters, brand wise, that you have found for use in the Model A Ford engine and WHY?
Thanks.
Pluck
kevinmac/toledo 02-15-2015 05:30 PM
Re: Best adjustable lifters for Model A
Thanks.
Pluck
steve; i like the hollow lifters ,to reduce the weight of valve train components. racing has taught us the accelerated wear with heavy components. i think this also helps with longevity....kev....brand of your choosing..
BRENT in 10-uh-C 02-15-2015 06:40 PM
The best tappets are manufactured by Colony, ...and are sold thru retailers.
SteveB31 02-16-2015 12:03 AM
Colony lifters are the best, but two of the larger vendors make their own lifters now, and they are NOT good lifters. Ask for Colony , and don't settle for any others.
Bruce of MN 02-16-2015 07:04 AM
Which retailers carry them?
john in illinois 02-16-2015 11:33 AM
Steve B31 owns Bert's so he probably sells them.
John
wrndln 02-16-2015 12:01 PM
The Colony double nut lifters I tried to use had the base that was too small compared to the other lifters - single nut I believe. Vince Falter has a good section about repro lifters on his website - link below. He isn't impressed with the small base on Colony double nut lifters. I tried to adjust the double nut lifters and it was a real task as the part on the lifter base below the double nuts was below the lifter housing in the block. I suppose you could cut off the top of the lifter housing, but I don't want to hack up the block to fix a problem that shouldn't be happening.
Rusty Nelson
http://www.fordgarage.com/pages/valv...comparison.htm
Jim Brierley 02-16-2015 12:22 PM
A large foot is necessary. I get mine from Arizona Model A, 480-782-0266.
Pete 02-16-2015 01:49 PM
You need to know what the cam you are running was ground for.
1 inch diameter lifters or 1.1 inch diameter.
Stock original cams require the 1.1.
BRENT in 10-uh-C 02-16-2015 03:14 PM
Yes very true, and not all info we read is 110% accurate. ;) :rolleyes:
CarlG 02-16-2015 04:12 PM
OK, so I have a Stipe IB330 cam. What diameter lifter should I have?
Pete 02-16-2015 04:32 PM
Originally Posted by carlg (Post 1034893)
ok, so i have a stipe ib330 cam. What diameter lifter should i have?
1.1
CarlG 02-16-2015 06:16 PM
Thanks Pete, I'll get the yardstick out when I get home.
Patrick L. 02-16-2015 06:25 PM
My intention is not to highjack this thread, but, does anyone still use originals ? Or, am I the only one that likes them ?
Pete 02-16-2015 08:02 PM
I make my own but they are NOT adjustable. (I do circle track race engines only)
Other than race applications on a model A/B engine, there isn't enough weight difference to use original type lifters.
Tom Wesenberg 02-16-2015 08:04 PM
I plan to keep my originals.
Pete 02-16-2015 08:09 PM
I haven't seen an original lifter for a long time. Aren't they 1 inch dia.?
d.j. moordigian 02-16-2015 08:19 PM
The originals are 1,125",....I believe there 2 styles of "mushroom" heads.
Thick and thin, depending on which Model A block you have..
Rowdy 02-16-2015 08:48 PM
The only originals I use are the B lifters, but I make them adjustable. Rod
Marco Tahtaras 02-16-2015 08:50 PM
http://abarnyard.com/temp/engine/cam/pushrod.jpg
