Old 03-29-2025, 01:24 PM   #1
kirkf
kirkf's Avatar
Default 1940 Pickup - Ebrake Cable Hold Down
On the e-brake cable there is a hold down that you can bolt to somewhere. I don't see an obvious spot where this would go. On my 1950 I believe it went to a transmission bolt, but I don't think the cable is routed the same way on a 1940
Attached are three pictures, which I hope will make clear what I'm asking.
The black hold down on the cable.
Thanx,
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 03-29-2025, 02:13 PM   #2
petehoovie
petehoovie's Avatar
Default Re: 1940 Pickup - Ebrake Cable Hold Down
Thanx,
Kirk
Old 03-31-2025, 05:40 PM   #3
kirkf
kirkf's Avatar
Actually I found my answer in Kube's book. It was hiding at the bottom of page 4-37.
"Also, the emergency brake cable clip (01A-2279) was fastened directly beneath the rearmost bolt head" (of reinforcement bracket 01A-5032) ref: pg-4-37, "Its Ford for '40", Mike Kubarth
That along with a picture Kube had previously sent me, made me realise I was trying to bring the ebrake cable up the wrong side of the frame rail. it should come up on the inside of the inner frame rail, and go under the clutch equalizer shaft.
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
