Old 05-31-2025, 02:54 PM   #1
tommyleea
Default 53 Ford Ranch wagon front seat install
I see the mounting holes for the front seat. But, looking at the seat it appears that the front should hook into some sort of bracket. Is this correct? Any help? Thanks. TommyJ
tommyleea is offline   Reply With Quote
Old 05-31-2025, 08:44 PM   #2
Newc
Newc's Avatar
Default Re: 53 Ford Ranch wagon front seat install
I am parting a 4dr '53 wagon, so pm me if parts needed. Newc
Old 05-31-2025, 08:51 PM   #3
Bruce_MO
I don’t recall any specific brackets that the seat base fits into. On my ‘53 Ranch Wagon, I just lifted the seat in and had a helper lift while I reached thru the interior to pull the seat across the hump. Then set it down to line up with the holes. But it was 25+ years ago. I’ll look at it the garage tomorrow to see if my recollection is off base.
Bruce_MO is offline   Reply With Quote
Old 06-01-2025, 09:15 AM   #4
tommyleea
Thanks, I will keep that in mind.
Thanks Bruce that would be great. TommyJ
Old 06-01-2025, 11:36 AM   #5
tommyleea
I am not sure if the front seat I have is correct. The seat adjuster lever on mine is on the left side. Should it be on the front? And it has a split back. Thanks. TommyJ
Old 06-01-2025, 02:45 PM   #6
TJ
TJ's Avatar
Check page 6-8 of the V-8 Club's 52-53 Ford book. Your seat is correct for the two door Ranch Wagon. If you do not have this two volume book you should buy it. Lots of great information on the 52-53 Fords.
Old 06-01-2025, 07:25 PM   #7
Bruce_MO
Yep the restoration guidelines are excellent. And I agree your seat sounds like the right one. My memory was pretty good… the seat brackets sit on the floor without any brackets or attachments to slide into. Simply held into place by two bolts on each side. Trying to attach a photo I just took under the seat. If I can attach the photo, you’ll see the floor sheetmetal in tan primer, and the galvanized bracket sits on the floor, with two bolts coming up thru the floor.
Bruce
Old 06-01-2025, 07:44 PM   #8
paul2748
paul2748's Avatar
On my 54 Victoria, the seat just sits on the floor, no bracket is used. I would imagine that the 53 wagon would be the same.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 06-01-2025, 08:11 PM   #9
petehoovie
petehoovie's Avatar
Bruce
Old 06-02-2025, 03:16 PM   #10
tommyleea
First of all thanks for all the inputs and photos. Here is a pic of the mounting points on my front seat. Tommy J.
Old 06-02-2025, 03:42 PM   #11
petehoovie
petehoovie's Avatar
Old 06-03-2025, 09:32 AM   #12
tommyleea
I think I read that a 4 door front bench seat wouldn't work in the 2 door ranchwagon. Why specifically wouldn't it work? Would it not bolt up or are there other reasons. Reason I am asking is that I have access to a front bench seat out of a 53 4 door car.Thanks..TommyJ..
Old 06-03-2025, 09:50 AM   #13
Bob C
I think in a 2 door the seat back folds forward so you can get in the back seat and the 4 door seat back does not.
Old 06-03-2025, 09:57 AM   #14
tommyleea
Yea...that makes sense. Thanks
Old 06-07-2025, 12:23 PM   #15
tommyleea
Talking seats, I guess I need something to bolt them to. Anyone have a source for some floor pans / patch panels for a 53 Ranchwagon? OER and classic industry say they have them, but the only thing that shows up is metal plugs for the floor pans. Thanks..TommyJ
Old 06-07-2025, 08:00 PM   #16
51504bat
51504bat's Avatar
I used floor pans from EMS for my '54 Ranch Wagon. Got them from Shoe Box Central. IMO easier to deal with Shoe Box than EN+MS Direct.
Old 06-08-2025, 07:25 AM   #17
tommyleea
OK..Thanks..For some reason I was thinking Shoebox wouldn't have them for the Ranchwagon. Good to know. TommyJ
Old 06-08-2025, 02:55 PM   #18
petehoovie
petehoovie's Avatar
Old 06-10-2025, 10:13 AM   #19
tommyleea
Looking at the front mounting area of my seat, does anyone have an idea what this seat might belong to? Thanks. TommyJ
