Old 03-01-2025, 07:14 AM   #1
drfromnc
Default 34 pickup Correct throttle knob?
Is this the correct throttle control knob for my 34 pickup? See picture
Based on my searching for new ones online at Dennis Carpenter and Third Gen Auto it looks to be the same shape (different color) but the same online sources also show a rubber grommet which I assume is used on the firewall?
drfromnc is offline   Reply With Quote
Old 03-01-2025, 07:45 AM   #2
deuce lover
deuce lover's Avatar
Default Re: 34 pickup Correct throttle knob?
Nope.What's pictured is 1932 which connects to a bellcrank. 34's have a long rod that goes from the dash thru the firewall to connect to the carb.
Old 03-01-2025, 07:55 AM   #3
drfromnc
Thanks “duece lover”. Ah, I do remember seeing short shafts on the new knobs online for my pickup.
So what secures the choke and throttle shafts where they pass thru the dash? Pictures please.
Old 03-01-2025, 08:03 AM   #4
deuce lover
The new ones are made with short shafts which you have to adapt to the long extension.Those long extensions were reproduced but not sure if still available.There is a slip on collar that connects them by welding.Rubber grommets for the dash and firewall which are reproduced..
Old 03-01-2025, 08:06 AM   #5
drfromnc
Awesome. Thanks again.
Old 03-01-2025, 08:11 AM   #6
deuce lover
Pics. The dash grommet is available in black or brown.Firewall in black only.Drake or Carpenter sells them.
Old 03-01-2025, 12:05 PM   #7
petehoovie
petehoovie's Avatar
Old 03-01-2025, 09:25 PM   #8
al's28/33
al's28/33's Avatar
same set up as my '33
1928 "A" Phaeton (mid year with many early features)
1933 "V8" Closed-Cab Pickup Truck
(originally a Model B, 4 Cylinder dating to May, 1933)
Old 03-01-2025, 09:27 PM   #9
al's28/33
al's28/33's Avatar
the short rods and handles are both repros and they connect to the longer rods behind the dash. I can get more pics if you need......
Old 03-01-2025, 10:38 PM   #10
Lawson Cox
Lawson Cox's Avatar
Best way to attach the collar, to join the two pieces together, is to use a center punch or small chisel, place it on an anvil or something to back it up, tap on it to tighten the two pieces Hardly noticeable. Welding would destroy zinc plating and look crappy. My 2 cents.
Old 03-01-2025, 11:41 PM   #11
al's28/33
al's28/33's Avatar
Lawson said it....... the two rods are attached with a collar .... exactly!
Old 03-02-2025, 01:18 AM   #12
deuce lover
Originally Posted by Lawson Cox View Post
[/B]
Lawson,I tried first your method which did not work,kept slipping out so finally I TIG welded the collar to shafts and silver painted over weld.
Old 03-02-2025, 07:33 PM   #13
Model51
Model51's Avatar
Back in the day, Ford swaged the short length which had the knob on the end to the long rod into the engine bay. Attached is a clip of one of the Ford Engineering Drawings for 1935 car rods. Other than the length and end point and angle of the rods, they were all about the same shape, a smooth bend from the fire wall to the carb.
Lawson has the right answer for how to best connect the two parts - just like Ford did.
File Type: jpg Figure 5-6-1 Choke and Throttle Knobs.jpg (11.4 KB, 35 views)
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 03-02-2025, 08:21 PM   #14
petehoovie
petehoovie's Avatar
