Old 02-16-2025, 09:56 AM   #1
Mike kitto
Default Filter
Air scoop on oil fill hole what do you use for a filter?
Mike kitto is offline   Reply With Quote
Old 02-16-2025, 09:58 AM   #2
19Fordy
19Fordy's Avatar
Default Re: Filter
Photo's please.
Old 02-16-2025, 10:35 AM   #3
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Filter
Oiled screen mesh. Equivalent to k&n
Old 02-16-2025, 10:56 AM   #4
KiWinUS
KiWinUS's Avatar
Default Re: Filter
Michael Driskell at thirdgen auto has correct replacement I believe.
Old 02-16-2025, 04:26 PM   #5
Kube
Super Moderator
Kube's Avatar
Default Re: Filter
Air scoop? Nope.
It's an engine breather.
Early design had a metal screen to keep the rocks out. Later models were stuffed with some type of mesh similar in appearance to coarse steel wool.
Photo attached is the later design...I think this one was used 1937 through 1948.
Old 02-20-2025, 03:59 PM   #6
35fordtn
35fordtn's Avatar
Default Re: Filter
Attached is a link to the 1937-48 breather and a link for the replacement mesh used on 1935-36 only
https://thirdgenauto.com/product/new...-breather-cap/
https://thirdgenauto.com/product/193...t-wire-screen/
Old 02-20-2025, 04:28 PM   #7
Bob C
Default Re: Filter
I though he was asking about the scoop by the fuel pump.
Old 02-20-2025, 04:36 PM   #8
petehoovie
petehoovie's Avatar
Default Re: Filter
[QUOTE=35fordtn;2370951]Attached is a link to the 1937-48 breather and a link for the replacement mesh used on 1935-36 only
NEW 1935-48 Ford oil filler fuel pump stand breather cap 78-6766
NEW 1935 1936 Ford oil filler scoop replacement wire screen M-92-04
Old 02-20-2025, 04:42 PM   #9
petehoovie
petehoovie's Avatar
Default Re: Filter
Old 02-20-2025, 06:17 PM   #10
Kube
Super Moderator
Kube's Avatar
Default Re: Filter
He was. It is not an air scoop. It is an engine breather.
