Old 11-15-2021, 11:48 AM   #1
52 Ford
Default 52 F1 tie rod end castle nut
Right side tie rod end the castle nut is lower than the cotter pin hole. Anyone else have this issue?
52 Ford is offline   Reply With Quote
Old 11-15-2021, 08:27 PM   #2
Bruce_MO
Default Re: 52 F1 tie rod end castle nut
I assume you mean there aren’t enough threads to fit the nut and get a cotter pin in. I have seen some variation in the length of the stud on tie rod ends. You probably have one that’s too short, and/or the steering arm boss is a bit too thick. Exchange it for another? Maybe you can compare a few to select the one with the longest stud.
Bruce_MO is offline   Reply With Quote
Old 11-16-2021, 10:37 AM   #3
52 Ford
No there are to many threads. When tight the cotter pin is above the castle nut
Old 11-16-2021, 12:29 PM   #4
TJ
TJ's Avatar
Are you sure you have the tie rod end with the correct taper? If you have the correct one then you can add washers to raise the nut or check around for a taller castle nut.
Old 11-16-2021, 03:20 PM   #5
1948F-1Pickup
1948F-1Pickup's Avatar
That’s a little unusual on a stocker. I replaced mine on the ‘48 a couple years ago with Moog pieces. Generally a bit more “generous” in the taper dimension than McQuay Norris or TRW items.
It’s not unheard of to need to add a washer under a tie rod nut, but mostly on a spindle where someone doesn’t know how to taper-machine correctly……. Not a situation with stock stuff.
1948F-1Pickup is offline   Reply With Quote
Old 11-17-2021, 09:45 AM   #6
52 Ford
Theses are Moog tie rod ends. The tapered hole in the spindle seems to be ok. I checked it with a set of calipers 5/8" all around the hole and the taper on the tie rod is 5/8".
Old 11-17-2021, 12:59 PM   #7
rotorwrench
rotorwrench's Avatar
If there is no difference between the nuts on same brand rod ends then the tapered stub part may have been for a different assembly at manufacture. This would show a difference in the threaded stub length. It should be no problem to washer it up. If the nuts are different then a person had to go looking for nuts.
In aerospace hardware, there are long thread bolts and short thread bolts and they have different castellated nuts for each on cotter pin applications. Long thread nuts have a taller profile.
