Old 03-16-2017, 02:31 PM   #21
toby
toby's Avatar
Default Re: 226 Fan/Alternator hitting each other
Everybody is correct. It is out of alignment.
Toby
toby is offline   Reply With Quote
Old 03-16-2017, 02:39 PM   #22
51 MERC-CT
51 MERC-CT's Avatar
Originally Posted by V8COOPMAN View Post
Wow, I hate to bring this up, but...............the more I look at the angle of the top of the block's deck where it meets the head, and then compare that angle with the way the alternator is sitting, it looks like the nose (pulley) of the alternator is also twisted somewhat toward the right (passenger) side of the vehicle. Look closely and you'll realize that we're seeing this engine from a slight FRONT angle.....not straight-on from the side. DD
As I said it could be an optical illusion caused by lens distortion and most likely is. The only way to know for sure is to put a straight edge across the pulleys. Till that is done no amount of 'guessing' will define if the pulleys are in alignment.
Most likely if nothing is done to correct any misalignment it will run for a long time the way it is without any problems.
Old 03-17-2017, 06:02 PM   #23
edhd58
edhd58's Avatar
Okay, I am just thinking out loud, yeah i realize what I said.
To check clearance, to have peace of mind, get the fan so 1 blade is straight up.
Get a piece of 1/2 inch thick plywood and cut it so it will drop down behind the fan while touching three of the fan blades.
While holding it against the fan. if it clears just fine you have plenty of clearance.
The fan isn't going to go rearward and the belt won't go forward that much.
does that sound reasonable??
edhd58 is offline   Reply With Quote
Old 07-25-2017, 01:30 PM   #24
Vintage Copper 47
Vintage Copper 47's Avatar
Originally Posted by sam03 View Post
No one ran into this problem? What am i missing?
I assume you resolved your belt issues.. but in case others made be looking for other options
On my 226 "G" model motor, I custom made an alternator bracket..
I used a double pulley on my alternator.. (just as my generator had a double pulley).. the challenge for me was getting wide belts that were the right or close to the right length.. I settled for narrower belts.. one of them I got from Grainger.. see photos..
WALT
"Old enough for the experience & too young to know better"
Vintage Copper 47 is offline   Reply With Quote
Old 07-25-2017, 07:57 PM   #25
edhd58
edhd58's Avatar
VINTAGE COPPER 47
Where did you get that double pulley, I've been looking for that exact thing for my G
Old 07-25-2017, 09:21 PM   #26
Vintage Copper 47
Originally Posted by edhd58 View Post
VINTAGE COPPER 47
I will have to check my receipt.. I bought pulley and 10s.i. alternator.. the alternator went south, 105 amps.. see another thread.. so I put the pulley on a 62 amp alternator..
I think this is the one I used.. 13mm
http://store.alternatorparts.com/par...ternators.aspx
Good luck! EDHD58
WALT
