Old 06-01-2020, 01:44 PM   #21
J Franklin
J Franklin's Avatar
Default Re: Timed my roadster - now runs worse
Originally Posted by Bob C View Post
Just take an old rotor and drill out the center so you can get to the screw slot.
Bob
Why not just do it right like Ford outlined? Take the rotor off and do it by the Ford manual!
Old 06-01-2020, 01:58 PM   #22
zzlegend
zzlegend's Avatar
Sounds right to me.
zzlegend is offline   Reply With Quote
Old 06-01-2020, 02:52 PM   #23
Kurt in NJ
Kurt in NJ's Avatar
Then read the next paragraph in the owners instruction book-- how to test that you have the timing set correctly--- as you hand crank it push in the pin, as it drops in the recess spark should occur
Old 06-01-2020, 07:15 PM   #24
40 Deluxe
Bob
But why??
Old 06-01-2020, 07:45 PM   #25
Bob C
Originally Posted by 40 Deluxe View Post
But why??
Makes it easy to set it like in post #16.
Also I guess you could ask why for the wrench in the picture.
Old 06-01-2020, 10:04 PM   #26
updraught
updraught's Avatar
If it's an old engine with low compression, say 50 psi or so then it may need to be advanced to give it some zip and zing on todays fuels. Maybe that is what the previous owner did.
Good to know how much compression you have anyway.
updraught is offline   Reply With Quote
Old 06-01-2020, 11:36 PM   #27
ABento
I also have a nu rex tool, and had the same issue of how it ran, this was on a BB, but it times the same, just no advance lever, I also used it on an A a few days ago and the way the wrench set it it was no where close to what the book says for setting the cam to where the points are just starting to open, about the only good I see in the tool is to hold the cam in place in case the screw was to turn it.
ABento is offline   Reply With Quote
Old 06-02-2020, 12:57 AM   #28
40 Deluxe
Since the timing lever gives a total of 40 deg. advance when fully down, there would be no need to mess with the setting of the distributor cam! 40 deg. is more than enough advance, even for a worn engine.
Old 06-02-2020, 07:47 AM   #29
updraught
updraught's Avatar
Well, maybe it is not advancing 40 degrees then. If it is noisier than previously, it is retarded compared to what it was.
Old 06-02-2020, 08:04 AM   #30
ryanheacox
ryanheacox's Avatar
It's been mentioned before but I'll ask again, did you make sure the point gap was correct before re-timing the engine? I've been stumped on the side of the road when my car started losing power and couldn't climb any hill just like you say. Then I remembered I installed a new set of points about 100 miles before, sure enough the gap had closed to almost nothing. Opened it up and away I went.
Also, could not agree more that once the base timing is set, do not mess with it again! I will also say that checking for spark at #1 when the pin drops into the dimple is the best and easiest sanity check to make sure your timing is set correctly.
Old 06-02-2020, 09:39 AM   #31
Bob C
I called Nurex when this tool first came out and they said it would not work on the B distributor.
Old 06-02-2020, 09:20 PM   #32
1crosscut
1crosscut's Avatar
Lots of good advice. Unfortunately Rivokid hasn't looked at this thread since shortly after he posted the original question and replied in post #3.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 06-02-2020, 11:15 PM   #33
jg61hawk
https://www.youtube.com/watch?v=3Xc7r0djEKo
https://www.youtube.com/watch?v=zju4nagtiCU
here are two videos part one and two of Les Andrews with pictures explaining the situation. I too found the Nu Rex tool was getting me in the ballpark, but when I manually did it with a test light as described here in the video and better so in his book, I had a better run. remember in the book it talks about CW and CCW ...pay attention...clockwise and counterclockwise!! I found his red book pretty easy to follow but you need a voltage light...
jg61hawk is offline   Reply With Quote
Old 06-03-2020, 06:04 AM   #34
mach0415
mach0415's Avatar
X2 I bought the NuRex tool and found that it gets it close, but a test light nails it for me too.
Thanks,
Mark in SC
"We the unwilling, led by the unknowing, are doing the impossible for the ungrateful." -- By society, who is still arguing over who said it.
mach0415 is offline   Reply With Quote
Old 06-03-2020, 01:05 PM   #35
zzlegend
zzlegend's Avatar
Maybe he broke down about 100 miles from home. May never hear from him again. But then again, a lot of posters never come back to give updates. Ok,,,,,,,,,,,,,,,,,,,,,,,,,,now back to mowing my lawn.
Old 06-04-2020, 05:47 PM   #36
burner31
burner31's Avatar
Easy solution
Just do it again
Keith
Shawnee OK
'31 SW 160-B
Old 06-05-2020, 06:27 AM   #37
Karl
Karl's Avatar
I must admit I have used the Nurex and have never been particulary impressed with it.
I normally time mine by finding TDC set the rotor up on number one then rotate the cam counter clockwise ( Removes backlash) and adjust the cam so that the slightest movement clockwise opens the points then lock the cam down .Easy quick and effective
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
