I need to replace the fuel sender float on the 37 Ford. I has what appears to be the original cork float that all the varnish has melted away and is now saturated with fuel. C and G offer two floats for these cars that are brass. Which, if any, of these will fit my sender and how are they attached? Thanks.
I had the same problem with my '37 and replaced the cork float with two of these >
http://www.snydersantiqueauto.com/gauge-float-only |
#3 | |
![]() Quote:
BTW - I epoxied the two together and sprayed them with clear, fuel-proof, model airplane dope....
Photo shows the removed original cork float and the newly installed replacement float.... Last edited by petehoovie; 01-25-2017 at 05:21 PM. |
I used a modern car float salvaged from a replaced fuel pump assembly--- look in the trash at most any garage
M 37,
A 94 carb float works quite perfectly....just solder it on the hook. Charlie ny |
The OE cork float on my '47 sender was saturated. Sender works fine. I had a Drake sending unit kit with a hollow poly-float bulb. It snapped right-in-place in the loop of the original wire arm of the old cork float.
#13 |
Look at the picture Mark posted of his sending unit above. There is no 'hook' on it like yours....
