I determined that I have a blown head gasket between 2 and 3 cylinders.I have a four blade fan and going to install the thrust collar in front to eliminate end play. Was debating going back to 2 blade fan making it easier to removed waterpump in future.Never had cooling issues. Actually runs cold even in hot weather. Appreciate opnions.
Two blade just because of the water pump. No need to kick your self later on.
Two blade
It's one thing all the looky-loos notice when looking at your engine, the other is the distributor and plug straps
x3. I got the cast aluminum one. Quality seems good.
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!" |
Two blade aluminum. After about 15 mph the fan really doesn’t do much anyway.
I agree also that it looks better. Enjoy. |
If you remove the studs from the head and use this kit it makes removing the water pump with the radiator in place easy.
http://www.snydersantiqueauto.com/pump-mounting-kit
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
Just beware, I replaced the 4-blade with a new 2-blade and it just touches the radiator hose now. Haven't yet pondered enough about what I'm going to do to remedy the situation. Maybe just put an extra set of rubbers under the radiator mounts to raise it up a hair.. I'm not running the hood anyway.
Nathan - 1929 Closed Cab Pickup, 1929 Tudor, 1930 Coupe, 1941 Pickup - Vintage BMW Motorcycle Collector/Mechanic |
Two blade Bob
I changed from a 4 to a 2 and used the Snyders kit.
