Old 03-17-2025, 09:49 AM   #1
WholeNewSetOfProblems
Default head bolt pressure
Question: To what pressure must heads bolts be torqued down to (Model A)? Thank you!
WholeNewSetOfProblems is offline   Reply With Quote
Old 03-17-2025, 10:13 AM   #2
katy
katy's Avatar
Default Re: head bolt pressure
55 ft-lbs
Old 03-17-2025, 10:20 AM   #3
nkaminar
nkaminar's Avatar
Welcome to the Barn. Please tell us a little about your car and where you live.
The recommended torque for the head nuts is 55 foot-pounds. Bring the torque up in 10 foot-pound steps from 25 foot pounds. Start the engine and let it run for 15 minutes. Let the car cool down and re torque. Then run 100 miles and re torque once the car cools down. Re torque after 500 miles. Always torque on a cold engine.
Old 03-17-2025, 11:40 AM   #4
Joe K
Joe K's Avatar
And don't forget to "pattern" torque according to some "force distributive" path.
Somewhere online is a "torque pattern" commonly used. You can't start at one end and work your way to the other end - rather "alternate your torqued bolts."
I see Vince Falter's "Ford Garage" site is back up and functional. He has a good page on this https://www.fordgarage.com/pages/tighteningsequence.htm
Joe K
Shudda kept the horse.
Old 03-17-2025, 12:24 PM   #5
JayJay
Copied from my (well used) Red Book. This (front to the right) is an end-for-end rotation of the one in Vince Falter's photo (front to the left).
File Type: jpg Model A_ Head Torque Sequence_LAndrews Red Book.jpg (21.4 KB, 30 views)
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
It isn't a defect, it's a feature!
Old 03-17-2025, 01:38 PM   #6
Follow-up question- I'm not at home, and need to buy a torque wrench- what size are Model A head bolts- thank you very much!
Old 03-17-2025, 01:50 PM   #7
Y-Blockhead
Y-Blockhead's Avatar
Wrench size is 11/16". My bad, JayJay corrected me.
I actually have the Genuine Snap-on 11/16" Obstruction Wrench for the Model A Head Nut under the distributor..
Old 03-17-2025, 01:56 PM   #8
JayJay
The nuts are 11/16". I use a 3/8" drive click-type torque wrench, a range of around 20-80 ft-lbs or so should be fine. There is one nut (nut #1) that is underneath the distributor. If you don't want to dismount the distributor to get to it each time you torque the head I'd suggest that you get one of these gizmos, along with a socket adapter to go from the 3/8" drive torque wrench (female side of the adapter) to the 1/2" drive of the gizmo (male side of the adapter).
And don't just bypass torqueing that nut because it's inconvenient to get to. That nut seals the gasket between the narrow parts of the #2 and #3 cylinder. That location (and between #3 and #4, nut #7) are the most vulnerable to head gasket blowout. They MUST be properly torqued.
JayJay
Old 03-17-2025, 02:01 PM   #9
ModelA29
ModelA29's Avatar
You'll need to remove the distributor or use this tool. It sounds like you are new to all wrenching on cars - buy the tool. Or get in touch with your local A club. Someone will loan you one or help you get it done.
https://www.snydersantiqueauto.com/p...8661&cat=41753
ModelA29 is offline   Reply With Quote
Old 03-17-2025, 02:06 PM   #10
JayJay
Originally Posted by Y-Blockhead View Post
Wrench size is ⅝".
Head nuts? You sure about that?
The bolts that fasten the water return goose neck and the side timing gear cover are 5/8". Front timing gear cover bolts are 9/16".
JayJay
Old 03-17-2025, 02:12 PM   #11
JayJay
I'd also suggest that you purchase a copy of Les Andrews' Model A Ford Mechanic's Handbook - Volume 1. Also known as the "Red Book", it is pretty much of a complete guide to service and maintenance of your Model A. Excellent reference, and written by a very nice guy whom I've had the pleasure to meet.
JayJay
Old 03-17-2025, 02:20 PM   #12
Y-Blockhead
JayJay, Just checking to see if you are awake, haha.
Old 03-17-2025, 03:10 PM   #13
JayJay
Yeah, well you caught me a few months ago, so all is well.
JayJay
Old 03-17-2025, 03:31 PM   #14
Y-Blockhead
JayJay, y'all going to CCRG in Visalia in a couple of weeks?
Old 03-17-2025, 04:43 PM   #15
ModelA29
ModelA29's Avatar
From what I've heard there must be 20 cars going from SoCal. I cancelled our room a couple weeks ago. The new seat for our Coupe won't be finished.
Old 03-17-2025, 04:54 PM   #16
Y-Blockhead
This Sunday we are headed in the opposite direction...
Old 03-17-2025, 06:00 PM   #17
katy
katy's Avatar
I was tought that on any cylinder head, start in the middle and work out in a spiral pattern.
In post #8, a 3/8" drive torque wrench was suggested. If you have to buy a torque wrench I would recommend a 1/2" drive as you might need it later for other jobs that require higher torque values.
Old 03-17-2025, 06:27 PM   #18
I appreciate all the advice. I'm thinking I don't have the competency or the confidence to tackle the torquing of these headbolts. I cannot get a response from local Model A Ford Club in Wsbg VA. Seeking any available assistance in Tidewater (located in Mathews, Va) thank you.
Old 03-17-2025, 08:04 PM   #19
JayJay
Affirmative. Flying solo, my bride backed out to spend the weekend with her three sisters in Bend, OR. Bunch from our club (Santa Clara Valley Chapter of MAFCA), I’ll PM you with details.
JayJay
Old 03-17-2025, 09:03 PM   #20
Ayers1
Ayers1's Avatar
If you can't get a response from a local Model A club, look up an AACA club. They frequently have Model a owners as members.
Also, if you don't want to buy a wrench like Jay-Jay shows above, I have a set of crow foot wrenches that can do the same thing. You can find a set of those fairly easily.
Ayers1 is offline   Reply With Quote
