Old 07-21-2016, 02:53 PM   #1
Mitch//pa
Thumbs up Doing it the primitive way
I hope it's perfect maybe I'll double check it with the stick
Ya think I'll be dog legging
Old 07-21-2016, 03:28 PM   #2
Larry Jenkins
Default Re: Doing it the inferior way
Boys with toys..
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 07-21-2016, 03:45 PM   #3
tbirdtbird
Default Re: Doing it the primitive way
we can only wish we had equipment like that....or access to someone who knew how to install it on an A
do I see some custom brackets going on there ?
'31 180A
tbirdtbird is offline   Reply With Quote
Old 07-21-2016, 03:50 PM   #4
Seth Swoboda
Seth Swoboda's Avatar
Is that the KR Wilson 4 wheel alignment tool?
Old 07-21-2016, 03:58 PM   #5
mshmodela
mshmodela's Avatar
Not very sporting!!! But hey, if you've got it, use it
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 07-21-2016, 04:10 PM   #6
Mitch//pa
deep dish wheel extenders that rest on the spokes so the heads clear the hub caps.
adjustable arms to grab the tires...
Old 07-21-2016, 04:15 PM   #7
99ZoomR
99ZoomR's Avatar
I'd guess that's a little more precise than my two yardsticks clamped together...
99ZoomR is offline   Reply With Quote
Old 07-21-2016, 04:18 PM   #8
qstott
qstott's Avatar
I see something is in the red! Is that the camber or toe?
qstott is offline   Reply With Quote
Old 07-21-2016, 04:22 PM   #9
Mitch//pa
I set it as best I could with a dubbie Gauge then put it on the rack.. It was approx a 1/4" toed out..
All steering & suspension compnents are tight...
Old 07-21-2016, 04:23 PM   #10
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Originally Posted by Mitch//pa View Post
I set it as best I could with a dubbie Gauge then put it on the rack.. It was 1/4 toed out..
Mitch, how much does spoke orientation matter on your set-up? Also, how much would a spoke need to be bent to affect a reading??
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 07-21-2016, 04:31 PM   #11
Mitch//pa
Since the rack does not have the program for a 1930 Model A I punched in a different car, it pulls up the specs for that car and that's why it's red....
I can still see what the readings are and adjust since I know what the specs are for the A
I can make a custom vehicle and enter the specs so I can use the bar graphs but I didn't do that yet
Old 07-21-2016, 04:48 PM   #12
Mitch//pa
Brent
Nothing will affect the reading
You do a forward rolling compensation which is approx 4-6" onto the front turntables. That calculates any issues ,,bent wheels etc,,etc.. And compensates for it automatically. The heads do not even need to be centered on the wheels as that is compensated for also..just slap them on and clamp it to the tire treads
Old 07-21-2016, 05:16 PM   #13
qstott
qstott's Avatar
It's a wonderful device!
Old 07-21-2016, 06:00 PM   #14
Patrick L.
Patrick L.'s Avatar
Pretty slick !
1/4" toed out. How did it handle ? Did you notice it ?
Is there a left camber problem ? Or, is it just a camera shot angle ?
Old 07-21-2016, 06:34 PM   #15
Mitch//pa
Originally Posted by Patrick L. View Post
Pretty slick !
It actually tracked pretty good toed out , the camber is fine...
Old 07-21-2016, 07:24 PM   #16
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Did you buy it @ Harbor Freight & HOW MUCH?
Dad Cheep
"THE ASSISTANT GURU OF STUFF"
Old 07-21-2016, 11:18 PM   #17
P.S.
Been there, done that.
P.S. is offline   Reply With Quote
Old 07-22-2016, 05:10 AM   #18
Mitch//pa
Nice Paul
Old 07-22-2016, 07:17 AM   #19
phonconn
Ben Hur would have be jealous of those fancy hub caps. Technology has sure brought us a long way, eh?
phonconn is offline   Reply With Quote
Old 07-22-2016, 07:31 PM   #20
KGBnut
KGBnut's Avatar
Forgive my ignorance, but what is a "Dubbie Gauge"? I have a home-made curtain-rod gauge that I am pretty happy with, and appears to give me pretty accurate measurements.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
