Old 06-21-2016, 07:21 AM   #1
1929
Default Mechanical Fuel Pump?
what is the possibility of a mechanical fuel pump on a Model A? was it ever done?
1929 is offline   Reply With Quote
Old 06-21-2016, 07:44 AM   #2
C26Pinelake
Default Re: Mechanical Fuel Pump?
where would it fit and why would you want it! What would it accomplish that an electric can not? Wayne
C26Pinelake is offline   Reply With Quote
Old 06-21-2016, 07:54 AM   #3
Special Coupe Frank
Special Coupe Frank's Avatar
Only if you're running a B or C block, which has a mounting boss cast in it, and you'll need a B or C cam, which has the fuel-pump lobe.
Unless you're really creative, and can somehow hang one on the valve-cover, the arm actuated by one of the valves...
Special Coupe Frank is offline   Reply With Quote
Old 06-21-2016, 09:50 AM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Now, the valve cover mounting is something I never would have thought about.
You can also use a vacuum tank like my friend's 29 Stutz has.
If I had some modification so it needed a fuel pump, I'd just use an electric pump.
Old 06-21-2016, 11:56 AM   #5
Bob C
Get creative like this. https://www.fordbarn.com/forum/showthread.php?t=196908
Bob
Bob C is online now   Reply With Quote
Old 06-21-2016, 08:59 PM   #6
Dodge
See above. There have been others that have done it also. Some machining involved and
you have to make up a fuel cam lobe in two pieces and weld it onto the model a camshaft.
Then you have to find a million dollar model B fuel pump.
Dodge is offline   Reply With Quote
