The Ford Barn
-   -   Mechanical Fuel Pump? (https://www.fordbarn.com/forum/showthread.php?t=198826)
1929 06-21-2016 07:21 AM
what is the possibility of a mechanical fuel pump on a Model A? was it ever done?
C26Pinelake 06-21-2016 07:44 AM
Re: Mechanical Fuel Pump?
where would it fit and why would you want it! What would it accomplish that an electric can not? Wayne
Special Coupe Frank 06-21-2016 07:54 AM
Only if you're running a B or C block, which has a mounting boss cast in it, and you'll need a B or C cam, which has the fuel-pump lobe.
Unless you're really creative, and can somehow hang one on the valve-cover, the arm actuated by one of the valves...
Tom Wesenberg 06-21-2016 09:50 AM
Now, the valve cover mounting is something I never would have thought about.
You can also use a vacuum tank like my friend's 29 Stutz has.
If I had some modification so it needed a fuel pump, I'd just use an electric pump.
Bob C 06-21-2016 11:56 AM
1 Attachment(s)
Get creative like this. https://www.fordbarn.com/forum/showthread.php?t=196908
Bob
Dodge 06-21-2016 08:59 PM
See above. There have been others that have done it also. Some machining involved and
you have to make up a fuel cam lobe in two pieces and weld it onto the model a camshaft.
Then you have to find a million dollar model B fuel pump.
