03-05-2013, 07:50 PM | #1 |
Electrical help needed!
I am an electric novice. I am planning to put a 12v power outlet in my Coupe so that I can charge a cell phone, camera, and mini speakers. How would I determine what amperage fuse I should put on the line between the outlet and the battery. Or should the fuse be on the negative side. I have a 12v negative ground system.
Thanks for your advice. marshall |
03-05-2013, 08:04 PM | #2 |
Re: Electrical help needed!
I'm certainly no expert, but I converted my Tudor to 12 volt 30 years ago. Just went through an experience with rewiring the A with a new loom set up with signal lights. Best advise I can give you is to look at Les Andrews' Volume 2. He gives a step by step instructions that are excellent. I have a fuse block on the starter with a 30 amp fuse. Using a 60 amp Delco alternator with an internal regulator. You will need a ballast resister on the 6 volt coil and one also on the horn and electric wiper if you have one. I kept the 6 volt starter and have never had any problem but it does spin the engine. Good Luck
Rick |
03-05-2013, 08:39 PM | #3 |
An inline 10 amp fuse to the center electrode should work fine.
03-05-2013, 09:07 PM | #4 |
I just put in a 6 volt pos ground to 12 volt neg ground plug in my coupe. I wired in a little box that does this for you. You can buy these units at most of the parts suppliers. It works great. But be sure you wire the correct pos and neg wires to the correct pos and neg plug hook ups. I wiped out my plug for my GPS because I had them switched.
Sorry did not want to spoil this posting but thought it might be interesting for someone that wants 12 volt neg in the car without having to put is a 12 volt system.
Fred Kroon 1929 Std Coupe 1929 Huckster |
03-05-2013, 09:59 PM | #5 |
Great point about watching for the negative ground since all the current devices are set up this way. As far as how big of fuse, the fuses are there to protect the devices, so it depends on the load. As stated above 10 amps is a great size and very common.
For those who want to figure out for themselves, use ohm's law. Power = current x voltage or P = I x E. If you have a 10 amp fuse, this is the max current (I). Your new voltage is 12 VDC (E). So 10x12 = 120 watts (P) of power available.
1930 Model A Fordor Murray Body |
03-05-2013, 11:51 PM | #6 |
I wired it in with a lighter outlet hidden up on the passenger kickboard. Works great, I use my GPS, power my phone, etc. P.M me I can send you some photos. Mine works great, $70 total, and took less than a hour to install. |
03-06-2013, 01:36 PM | #7 | |
03-06-2013, 01:53 PM | #8 |
How do we always get off track and not really answer the question. Read the thread again, he ALREADY has a 12V system installed, all he wants to know is how big a fuse to use for the 12V outlet/power point he wants to install.
Sorry if I ranted. Paul in CT |
03-06-2013, 02:11 PM | #9 |
"Sorry did not want to spoil this posting but thought it might be interesting for someone that wants 12 volt neg in the car without having to put is a 12 volt system."
03-06-2013, 02:17 PM | #10 |
Look at the wattage of the device you're going to plug in. To determine the fuse size. Volts X amps = watts. therefor if you know the wattage and the volts(12) the formula is watts divided by volts equals amps. then you know the size of your fuse. Now find a wire/amperage guide and select the proper guage wire (size).
'31 Fordor Deluxe 2W Briggs 170-B / blackwalls '41 Fordor Deluxe / 2-duece flattie '66 1/2 Dodge Charger '14 100th Anniversary Challenger Limited Edition. Semper Fidelis |
03-06-2013, 02:19 PM | #11 |
The second part of your question. Fuse on the positive side.
03-06-2013, 02:24 PM | #12 | |
03-06-2013, 02:27 PM | #13 |
To run a cell phone charger or a GPS unit, all you need is a 1 amp fuse. You could bump it up to a 3 amp fuse and have plenty of protection.
Jim Cannon Former MAFCA Technical Director "Have a Model A day!" |
03-06-2013, 02:38 PM | #14 |
I just used a magnifying glass to read the extra fine print on my cell phone charger. I calculated 2 amps at 12 volts input.
03-06-2013, 10:55 PM | #15 | |
Jon "If you choose to not decide, you still have made a choice!" RUSH Don't tell me what you know..... Tell me what you have done. |
03-08-2013, 01:52 PM | #16 |
Bruce nailed it with the statement that the fuse protects the wires. Sorry I skipped over that VERY important detail. I had that in mind when I stared typing, but lost it with everything else.
