#1 |
Is anyone running a Vertex on a street motor? Are you using an internal or external coil? Did you get a flathead mag. or have a Chevy converted to flathead? What did you do about the advance? Thanks, Craig.
" When I was a boy of fourteen, my father was so ignorant I could hardly stand to have the old man around. But when I got to be twenty-one, I was astonished at how much he had learned " Mark Twain. |
#2 |
I am not running a Flathead, I am running a Chevy on the street with a Magneto. If you run a locked advance you will need to be careful in your timing. If you are lucky enough to find one with advance for a Chevy or any other make besides Flathead you will need to have it curved for the Flathead. They can't handle as much as a Chevy. Chevy starts at 10-12' and goes all the way to 40' for a really radical one. Flatheads are best on about half that for total advance. But if your question is can it be done- Yep! many trouble free miles on mine. Internal coil is the way to go no muss no fuss.
Tim |
#3 |
The Vertex mags take a fair amount of torque to pull them through a rotation. The Fairbanks Morse takes a lot less torque to turn. Most mags were set up to run full advance with an impulse coupling to retard em for starting. You don't see them on too many street cars for that reason.
#4 | |
The vertexes are expensive but a good used Chevrolet unit is pretty easy to find and machine for the flathead. Advance can be added to any of these mags but could very well cost $350 or so. About half the ones we have done had no advance. Doesn't seem to be a major issue on the flathead. Just set the timing at 2500-3000 rpm to be approx 20 degrees etc for a max timing, and take some care when starting the engine., toggle switch the engine and crank for a round or two before turning the mag on. They seem to run ok like this with no overheatingproblems etc.. We have also used a few with bad mag coils ( too expensive to repair) by taking the coils out for a no load mag look a like using only the vertex ignition points and a hidden ignition remote mounted coil. These also work very well. If for no otherreason they have the look for sure.... |
#5 |
If you are using a 6 volt starting system the Vertex is a poor choice. They will, however, generate enough fire for starting when the engine is spun with 12 volts on the starter.
#6 |
Have it setup with advance curve for a flathead and You are fine |
