#1 |
I recently picked up a rear center section and metal floor pan for a '28 Phaeton from Mac's, I'm disappointed with the fit, missing holes, missing re-enforcing plates etc...are all the replacement parts like this? I found the same thing with most of the reproduction parts I've used along the way, I'm I shopping at the wrong place? Frustrated!
#2 |
No just about all reproduction metal will need work to make it fit.
#3 |
Sounds like Mac's is buying his sheet metal from Howell's.
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? ![]() |
#4 |
I think both Chris and Mike are right. I have a rough 29 phaeton I bought a little over 3 years ago that come with a repro rear panel as the original rear panel had about 2" of the bottom rust off. I looked at the repro and it was like you stated, not good at all. After looking for a while I found a better original panel (bottom was pretty good, but the top need a lot of work). The arc of the rear panel was what I found lacking on the repro panel. I suspect Howell's made the panel. After buying a couple of sheetmetal items for them years ago, I decided to never knowingly purchase anything they made in the future. The problem is that some venders like Mac's wont tell you where the sheetmetal item was made, I guess for fear you will buy the item directly from the maker of the item. I also don't buy anything from Mac's anymore for that reason - it happened twice to me. There are several much better parts suppliers, like Bert's, Bratton's. Maybe Howell's is making better panels now, but I doubt it. I agree with Mike that most sheetmetal are not made very well. They get to maybe 80-85% correct and then stop. Brookville roadster makes some very nice reproduction sheetmetal like the stamped floorpan under the front seat - dead on. However, even then, some of their sheetmetal is not so good. Just my opinion - for what is it worth.
Rusty Nelson |
#5 |
I may try my luck at repairing the original.
#6 |
#7 |
I understand that Macs has a new owner. Iceman
#8 |
![]() Well here are your options as I see it, you repair your original (possibly used sections of the Howell panel), or you use the Howell panel with work, -or you do as we have done and make on from scratch. The true issue for making these panels is how much are you willing to spend? Even with us using a Pullmax, pneumatic Planishing Hammer and an English Wheel, we will have 25-30 hours in making a duplicate panel that matches the original in all details. This is more than most folks really want to pay for something like this so there must be a balance. Once option may be to see if Flop would be interested in repairing yours?? |
#9 |
Brent is right on all 3 options. I was faced with needing a rear floor pan for a 1930/31 roadster. [TRUNK] not a rumble seat which hides most of it. $1,200.00 later [1980 prices] i had a perfect reproduction floor pan . ENFIELD Auto restoration [Conn.]does very high end restorations for years. Back in the late 70's they restored a 400A with a tree growing in the middle of it. Won high Awards at that time by all clubs.Same goes for a 1930 BLACK Deluxe and Standard roadster owned by the same person. The Deluxe was missing the complete floor 6 inches up the body panels... YOU have the bucks anything can be done! It also depends on what level of restoration you are looking for.
#10 |
I guess I am about the only guy to have good luck with Howell.
my cowl quarter pannels fit nice just a slight amount of adjusting that I expected. The u-channel for the rear of my bed fit perfect and the one door skin I bought need no adjustment.. I must have hit them on a good day lol |
#11 |
Eckler owns macs now.
#12 |
Ecklers may have their hands in too many pots, the sales staff at Mac's are not too knowledgeable regarding "A's", you give them a part number and they go to the back and get it, I asked a few questions and their answer was "we work with part numbers, give us a part number we will get you the part".
#13 |
Thanks for all the thoughts
#14 |
Take some time to learn metalwork and try making your own. I found it was not super hard to make the bottom 3" to 6" of my slant window cabriolet once I learned some of the science behind moving metal and understanding about metal shrinkage.
If it does not go right then you have to resort to other techniques. You do not need to spend $$$ on many special tools. You just need to have a few of the right tools and the imagination on how to make jigs for your one off project. Oh and time, if you are in a rush you might not figure it out. See my website for ideas and where to find more websites on how to do metal work. |
#15 |
Been using Brattons and the fit is NOT perfect but pretty darn good.
A7191-Sport Coupe 29 Roadster 29-Town Sedan 29-Original Special Coupe |
#16 | |
![]() Quote:
The problem with that is Brattons buys their rear panels from Ryan Howell too, ...and sadly the fit and shape is NOT good!! If you have nothing, it IS a good starting point but they are a long way from being worthy to install on most people's phaetons. . . |
#17 | |
![]() Quote:
End and correct.....ya need something for a base...right ![]()
#18 | |
![]() Quote:
#19 |
Like I keep saying "Aftermarket" stands for "Almost Fits". Like Brent said How far do you want to go. I'm working on a 1930 Deluxe Coupe and I'm into 900 hours on the body and paint. And I still have another 100 -150 hours to go before it's together and ready for Upholstery. From Bits to a complete car. Every Aftermarket part I had to rework to make it close to right or to make it fit.
The Old Tinbasher |
#20 |
Ryan Howell owns Howells Sheetmetal, a company in texas that makes some of the sheet metal parts for Model A Fords, Model T Fords, V8 Fords and some other cars. They make some good parts, and some not as good parts.
