Old 02-22-2013, 08:08 PM   #1
al pa.
Default fuel sender
47 merc.had tank cleaned and sealed.is it possible to test stock sender and gage using a 6 v lantern battery,before installing sender in the tank,and if possible,how to route test wires.
al pa. is offline   Reply With Quote
Old 02-22-2013, 09:16 PM   #2
f1builder
Default Re: fuel sender
you might do a search, i read something a while back on how to check for ohms on a sender but don't recall details.
f1builder is offline   Reply With Quote
Old 02-22-2013, 09:46 PM   #3
41ford1
41ford1's Avatar
Certianly can. Use 3 clip leads. One from battery neg to one terminal on the gauge. One from the other terminal to the sender teminal. The last from the sender flange to battery pos. Move the float and observe the gauge action. These systems do not react quickly so allow a 10 to 15 seconds for a reaction.
41ford1 is offline   Reply With Quote
Old 02-24-2013, 06:23 PM   #4
al pa.
i thought the sender flange was negative ground on 47?
