Old 02-13-2013, 01:58 PM   #1
Dune Country
Default painting steps
'31 CCPU
getting ready to paint the cab and box.
Using concept w/med reducer. would/did you paint the interior first then mask? or all at once w no overspray?
tnx
Dune Country is offline   Reply With Quote
Old 02-13-2013, 02:16 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: painting steps
Define "med reducer"? Are you saying DT860 DT870 or DT885, --and what temps are the air coming across the sheetmetal? Also, what kind of gun and what is your physical strength like? It can be painted all at once with a slower thinner however your 'stamina' needs to be there (tired hands, arms, & brain cause runs!!). No harm in spraying in stages if that is what it takes to get a slick finish.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 02-13-2013, 02:25 PM   #3
BRENT in 10-uh-C
Some inspiration.....
BRENT in 10-uh-C
Old 02-13-2013, 02:51 PM   #4
Hicktick
Hicktick's Avatar
Brent I thought that the gas tank was installed before painting ???????
Is that a black sealer sprayed on the bottom ????
I learn something new everyday .
Hicktick is offline   Reply With Quote
Old 02-13-2013, 03:05 PM   #5
BRENT in 10-uh-C
Originally the gas tank WAS installed prior to painting. So were the doors however we don't do it that way!
The bottom is Rock Moss Green too (in satin finish). The lights inside a spray booth can be deceptive when judging colors.
BRENT in 10-uh-C
Old 02-13-2013, 03:27 PM   #6
Dune Country
70deg reducer, shop temp about 65, HVLP gun w/ 1.4 tip. stamina is ok, used to paint big trucks.
I noticed in your pictures that the door looked to be masked, did you paint the other side first?
Old 02-13-2013, 03:29 PM   #7
ford3
ive found that if you try to paint every thing at one time,eventually you will drag a hose over the wet paint or touch it with your hand or some part of your clothes, so i paint in steps, takes a little longer and maybe costs a little more for materials, but the chance of having to touch up some thing is greatly reduced, even when painting my 50's street rods i paint in 2 steps even when painting one color, i paint the hood. roof and deck lid, then i mask and paint the rest of the car, quarter panels and front fenders,no chance of having the air hose touching wet paint, but thats just me
ford3 is offline   Reply With Quote
Old 02-13-2013, 03:48 PM   #8
Hicktick
Hicktick's Avatar
Thanks Brent , I see the lower color now .
Old 02-13-2013, 04:29 PM   #9
Farrell In Vancouver
Farrell In Vancouver's Avatar
Hey Brent,
How much paint does your crew throw at the roof bows?
Just a single coat? Or is it hit a few times and allowed to soak in?
Farrell In Vancouver is offline   Reply With Quote
Old 02-13-2013, 05:58 PM   #10
stainless steve
stainless steve's Avatar
Brent ;you seem to restore many ..As.. Im looking for a color code for Rose Beige for my 29 sport coupe my supplier says they cant cross the IM 119 dupont color to Sherwin williams nobody else sells dupont or Ditzler in my area. My supplier sold all them but SW bought them out and they say they cant crossreference them ...I think its a bunch of hoecum but who knows.Hopeing you might have a code thats close???
stainless steve is offline   Reply With Quote
Old 02-13-2013, 08:29 PM   #11
ford3
steve, i have two codes, dupont ds 086, and ppg 119
Old 02-13-2013, 10:10 PM   #12
stainless steve
ford3 I have those codes also .Thank you I will do more searching and watching this thread. Im not understanding why they cant crossreference these,they used to do it all the time .My car had been stripped and painted in late 60s early 70s (i was told)so no paint chips or anything to match up with. all I found was a little Seal Brown and a peice of orange stripe under one door handle and the paint on car ,trim,headlights and everything was copper. I was curious if any other #s had come up
Old 02-14-2013, 09:11 AM   #13
eystein
eystein's Avatar
Brent,
If you paint the tank and cowl separately, how do you get the cowl welting painted ?
And, while I'm at it, how do you get the tank/cowl/welting assembly raintight? Do you use any kind of sealer ? (I will be using Roy Naczewitz' welting.)
eystein is offline   Reply With Quote
Old 02-14-2013, 09:47 AM   #14
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by eystein View Post
Brent,
Paint it first.
Old 02-14-2013, 12:48 PM   #15
stainless steve
Found a local jobber for Dupont .......yea....Can and will mix these colors....I quess some places arnt interested iF its not in computer back on track
Old 02-14-2013, 01:12 PM   #16
ford3
LOL Steve, sounds like Auto Zone, they dont own a catalog, if its not in the computer its not made
Old 02-14-2013, 02:25 PM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
So, where are these steps you are painting?
Old 02-14-2013, 02:31 PM   #18
eystein
eystein's Avatar
Originally Posted by Mike V. Florida View Post
Paint it first.
So, Mike, if you paint the gas tank welt first, how do you manage to install it without cracking off the paint? And, how do you get the assembly rain-tight ?
Old 02-14-2013, 04:06 PM   #19
BRENT in 10-uh-C
Brent,
See below. If the tank properly fits the cowl, then it will seal.
Well I am not Mike but our method is to use the correct type welt that has be "fitted" first. Then spray one light coat of color (with flex agent optional) and then install when dry. Two or three things gets you into trouble if you do it incorrectly. First off, I am using a non-plastic type welting so paint sticks better. Wipe it thoroughly with Wax & Grease Remover and then spray with Bulldog Adhesion Promoter just prior to color coating. Next, only one-coat it as it doesn't need multiple layers of paint. Having it prefitted reduces the handling which reduces the chances of damage during installation. Look on the left side of the 1st picture below.
BRENT in 10-uh-C
Old 02-14-2013, 04:30 PM   #20
Logan
Logan's Avatar
Paint both the inside and out at the same time. It's easier that way and a truck can is really small. But if you feel like you might not be fast enough or have enough stamina the pain the can and bed at seperate times
Cowtown A's
Logan is offline   Reply With Quote
