#1 |
Just picked up a set of edmunds heads and intake. Never installed aluminum heads before 47Ford. I'm going to get the heads checked but is there anything different about installing them ( head gaskets or mounting nuts or studs ) Thanks
#2 |
there was a good thread on this a while back but i don't know if it was here or on the hamb. do a search and see what comes up. on mine i didn't do anything really different except i used the chamfered washers on them, without the o ring and they didn't leak for as long as i kept the car.
#3 |
If they're anything like the Weiand heads I've just bought for my 47 engine, you'll need to put the long studs in, and use hardened washers.
#4 |
As well as the above information, use composite head gaskets, and liberally coat each head stud with nickel based antisieze compound to help keep electrolysis at bay. Use a 50/50 mix of coolant to also assist in preventing this.
#5 |
I use metal head gaskets with my alum. heads and coat the head, both sides of the gasket and block with copper coad spray on sealer. Have not had a leak problem. I use a sacrificable anode in the rad also. My experience with the composite gaskets is that they are a real pain to get a head off from and a mess to clean up after.
#6 |
#7 |
I posted this before but I guess it didn't go anywhere. These are direct replacement heads of hi compression (8:1). They have a relocated spark plug that allows the use of a power tip plug, for better combustion of a lean mixture. Thes castings are quit thin so don't expect to run a high lift cam with out running into water. Great heads for a stocker.
The intake works best with 2" risers, better throttle response. This is a good combination with the right ignition system, a crab dist in good condition is about the best you can run is the early engines and a converted GM with Vac in a late engine. Good power, great mileage. |
#8 |
Old Ron Sent you a message Thanks
