#1 |
I am converting my 1929 standard coupe brakes to hydraulic and would like to install a dual master cylinder to make it a little safer. I was wondering if anyone had any advice on which one to use and where to buy one for a reasonable price.
#2 |
Typical is the dual cylinder off a 67-70 drum-brake Mustang. Most all parts houses have one listed and since they are "normal", they aren't terribly expensive.
#3 |
Contact Cling's in Tempe, AZ 480-777-5904. They make hydraulic conversions for the Model A, Their master cyl kit is very well done, fits up close to the brake pedal. Very easy installation.
Tom Endy |
#4 | |
![]() Quote:
.................... ![]() ....oops, sorry!! ![]() . |
#5 | |
![]() Quote:
Charlie Stephens |
#6 |
#7 |
Thanks everyone for the information. I am building everything myself on this restoration so I am not using a kit and will use Bill Lee's suggestion.
#8 | |
![]() Quote:
#9 |
Not necessarily easily noticeable on a casual walk by MikeK. I ran a setup for a customer where the master cylinder was completely hidden and the brake lines ran the same route as the original rods so on a casual walk by it looked normal but upon in depth inspection everything was there.
#10 | |
![]() Quote:
Cowtown A's |
#11 | |
![]() Quote:
A fine point car that scores 250 of 500 possible is still considered a restoration, albiet not perfect. If that car had juice brakes it wouldn't even be judged. That set of definitions would see it as a modified vehicle. If it were a substitution of lamps and a different generator, it would just loose points, and still be considered a resto. So where do you personally draw that fine, fuzzy line? A little or a lot to the right or left of someone else's definition of resto, resto-mod, and modified vehicle? Some people consider the fine-point JS extreme, some think they don't go far enough! And then there's the MARC "Touring Class" which is a much looser set of definitions. The fine point JS has their set of definitions The MARC Touring Class has theirs You have your set I have mine. Last edited by MikeK; 02-03-2013 at 11:42 PM. Reason: spelling |
#12 |
Here is some info on mustang M/C. Note you want one for drum-drum brakes. The rear outlet-closest to pushrod-is the front brake port. Summit racing sells it for an ok price. I use this with 40 Ford rear brakes and 39 Lincoln copy front brakes.
http://www.cjponyparts.com/tech-dual...ylinder/a/147/ Another good link. https://sites.google.com/site/mrtexa...ydraulicbrakes Also lots on HAMB Good luck,John |
#13 |
the outlet closest to the mounting bolts goes to the rear, also use a 1 inch bore not the 15/16 bore
#14 |
#15 |
#16 |
Wow, now what to do. you are the guy that should know, I bought my battery box from you on eBay but there was also a long thread on the hamb about those mc and they deducted that the port closest to the mount is for the front. That is now how I have mine. I would Jaye to have to rerun my lines.
#17 |
#18 |
mrtexas: Your install pictures answer all the questions. JMO Nice install! !
Paul in CT |
#19 |
I followed Dave's diagram that I got with the battery box/Mustang master cyl. I hooked up the front outlet to the front brakes. I found that I had to adjust my rear brakes very loose or they would go on before the front brakes. I used them for about a year. I looked on the internet and found the piston nearest the rod or mounting bolts is the primary piston. The back piston is the secondary and goes on after the primary is pressurized. Anyway I switched the front brakes to the back piston and now they adjust normal. .
Here is the link about Mustangs that spells this out. http://www.cjponyparts.com/tech-dual...ylinder/a/147/ Ford trucks http://www.chtopping.com/truck.html My 2c,John PS Dave's products are great. Battery box,4speed f150 trans.very happy-16,000 miles Last edited by john in illinois; 02-04-2013 at 09:24 PM. Reason: add words |
#20 |
after much study ,port closest to the mounting flange rear brakes
