Old 01-26-2013, 06:00 PM   #1
chopo
Default what is this tool?
came with some parts i got
chopo is offline   Reply With Quote
Old 01-26-2013, 06:11 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: what is this tool?
It looks like when you squeeze the handle the barb would grab a bushing or bearing race and you can twist and pull it out of a blind hole. I might be wrong, but that's my guess since I haven't seen such a tool before.
Tightening the large nut would pull the bushing or race out.
Old 01-26-2013, 06:51 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
The tool has to be held on, since there is NO lock. With the "O" ring, it's meant to seal some liquid outlet temporarily, like when filling MOONSHINE jugs! Bill W. (But HONEST, Ossifer, Sir, it's just xtra FUEL!)
"THE ASSISTANT GURU OF STUFF"
Old 01-26-2013, 06:53 PM   #4
chopo
moonshine does some crazy things to people huh Bill W.
o-ring....?
Old 01-26-2013, 07:29 PM   #5
BILL WILLIAMSON
o-ring....?
Yo, chopo, Dog riled,
Ol' Bill might NOT be the BRIGHTEST marble in the bucket, but he knows his "O"RINGS. Just blow up the pic-----SEE! it's round & BLACK! LIKE, O O O O O O----"O" rings aren't made just to look purty, they SEAL stuff!-----GOT IT?? Buster T.
Old 01-26-2013, 07:34 PM   #6
MikeK
MikeK's Avatar
Removes a single-use knock-through barrel bung like this one: LINK ?? I see a groove, not an O ring in the pix...
MikeK is offline   Reply With Quote
Old 01-26-2013, 08:08 PM   #7
Drive Shaft Dave
I believe this tool is used for installing door and trunk handle ferules on twenties to thirties GM vehicles.
Drive Shaft Dave is offline   Reply With Quote
Old 01-26-2013, 08:30 PM   #8
Special Coupe Frank
Special Coupe Frank's Avatar
Yep.
Special Coupe Frank is offline   Reply With Quote
Old 01-26-2013, 08:34 PM   #9
2manycars
2manycars's Avatar
Yes, that is why there is an adjusting nut, to set the tool for the length of ferule and thickness of the door.
2manycars is offline   Reply With Quote
Old 01-26-2013, 08:48 PM   #10
Tom Wesenberg
Oh heck, there goes my stuffed animal.
Old 01-27-2013, 12:29 PM   #11
BILL WILLIAMSON
Wish you lived close, Tom, I'd FIX you up. Pat collected stuffed critters! Must be 77 of them dudes EVERYWHERE! Peering out from the most UNEXPECTED places Buster chose a life size 'coon to "KILL" about 9 times a day! I told him it was Pat's & he NEVER tears it up! Bill W.
Old 02-01-2013, 10:17 PM   #12
Tinbasher
Tinbasher's Avatar
Yup!! That's it. Used to install the door handle ferule on GM's. Used one a couple of times!! The Old Tinbasher
Tinbasher is offline   Reply With Quote
