Old 01-24-2013, 07:13 PM   #1
TinCup
TinCup's Avatar
Default Spongy Mechanical Brakes
I just spent the last couple of days changing out my bonded composite shoes for new woven shoes and linings. I have arced the shoes to the drum and have them centered. New springs, new rollers and pins. New brake rods were installed last year.
My challenge is the brakes feel spongy. Yes they will stop but the pedal doesn't feel firm, it feels soft. I have driven other A's with mechanical brakes and they have a harder pedal.
I have used the brake buddy to adjust the brakes 60-40 back to front.
Good thing I chose to do this as I found the drivers side rear wheel bearing was bad.
What am I missing???
TinCup is offline   Reply With Quote
Old 01-24-2013, 07:37 PM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Spongy Mechanical Brakes
Yo, Okie Brother,
Iffin' you got 1 or 2 brake rods with some small wiggledy woggles in them, they can feel soft. Maybe as your shoes wear in to the drums a little, the "feel" may get "harder." OH! & throw away that board & adjust each wheel 'til it just locks up & back off 3 or 4 knotches, TRUST me, I do know what I'm tellin' you WORKS! Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 01-24-2013, 07:50 PM   #3
roccaas
roccaas's Avatar
What is the result of mounting the anti-rattle springs on the wrong side of the brake rod nubs??
20 years ago we had Johnny Cash, Steve Jobs, and Bob Hope. Now we have no Cash, no Jobs, and no Hope...please don't let Kevin Bacon die!
roccaas is offline   Reply With Quote
Old 01-24-2013, 08:28 PM   #4
Tom Wesenberg
Tom Wesenberg's Avatar
Then the won't help return the brake pedal. If they push againt the bump in the rod from the wrong direction then they are helping to apply the brakes.
Old 01-24-2013, 08:29 PM   #5
brum1
brum1's Avatar
If the drag is right it should take the sponge out of the pedal-assuming all your mechanicals are good
"no one knows more than everyone"
brum1 is offline   Reply With Quote
Old 01-24-2013, 08:42 PM   #6
d.j. moordigian
d.j. moordigian's Avatar
Ahhhhh........Power Brakes
d.j. moordigian is offline   Reply With Quote
Old 01-24-2013, 09:08 PM   #7
BILL WILLIAMSON
Thanks, D.J, I've been tryin' to come up with sumptin' bettern' a bag of sand on a rope tied to the door handle. I think the sponginess in MY brakes is the DRIVER Bill W.
Old 01-24-2013, 09:10 PM   #8
Mitch//pa
no bill,
you have air in your system
Old 01-24-2013, 09:24 PM   #9
eagle
eagle's Avatar
I don't understand all the troubles some people have with the mechanical brakes. Mine work perfect and are no harder to apply than the hydraulic brakes on any of the older nonpower assisted cars. I can skid my wheels anytime I want, stops straight, don't fade...work great.
eagle is offline   Reply With Quote
Old 01-24-2013, 10:33 PM   #10
Mike V. Florida
Mike V. Florida's Avatar
Location: Florida between Sarasota and TampaSouth Florida
Originally Posted by Mitch//pa View Post
no bill,
GasX takes care of that.
Old 01-24-2013, 11:31 PM   #11
Bubby Sharp in KY
TinCup, Check the cross shaft for slop in the bushings also check the brake and clutch pedal shaft and bushings for slop . All pins need to fit without slop , You can use oversize pins to compensate for wear. Bubby Sharp in KY
Bubby Sharp in KY is offline   Reply With Quote
Old 01-24-2013, 11:49 PM   #12
Charlie Stephens
Spongy? Are the brake rods bent?
Charlie Stephens
Old 01-25-2013, 07:21 AM   #13
Del in NE Ohio
Del in NE Ohio's Avatar
I've seen guys spend all their time/money on the four corners of the brakes with disappointing results only to find that the service brake cross shaft was sloppy. If the cross shaft is compromised, all your work down stream will likewise be less than effective.
Del in NE Ohio is offline   Reply With Quote
Old 01-25-2013, 10:29 AM   #14
TinCup
TinCup's Avatar
When I replaced the brake rods last year I replaced all the pins. Some of them required the oversized pins. The cross shaft is not sloppy.
Old 01-25-2013, 10:51 AM   #15
gweilbaker
gweilbaker's Avatar
Maybe have someone exercise the brakes whilst you inspect the movement from pedal to wheels, you might find something unexpected.
gweilbaker is offline   Reply With Quote
Old 01-25-2013, 10:53 AM   #16
grapp
As stated above, two things to really keep an eye on, first have someone step on the brakes while you really check to see if the brake rods flex or are bent, after all they are very old.... The second it what bill said, try manually adjusting them. as a side note, did you cut the drums, or measure them? are they in spec? And lastly new pads sometimes need to seat, so it may be that they just need to be driven, sometimes a quick sand paper rub across them speeds that up....
grapp is offline   Reply With Quote
Old 01-25-2013, 12:47 PM   #17
H. L. Chauvin
You probably already checked this.
But FWIW, if the right rear brake lever, (camshaft lever), was installed on the left, & the left rear brake lever was installed on the right, the rear brake levers are at a slight incorrect angle for proper alignment; hence, the rear brake rods are tightly arched like a spring as opposed to being straight.
Not all new rear brake levers are marked "RH" & "LH" -- then some get confused with "RH" & "LH" as opposed to referring to driver's side & passenger's side.
In not observing the slight angle on tops of rear brake levers, it is easy to incorrectly install same.
Even if this is not the problem in your case, it may help someone to be cautious on a future brake job.
Another cause for a sponge effect may be that a space exists between the brake band(s) & the brake shoe(s) at a location (or locations), between pairs of rivets; hence when brakes are applied, the brake band has to be compressed before it contacts the solid brake shoe for full contact with the brake drum.
Just keep looking -- probably something very simple.
H. L. Chauvin is offline   Reply With Quote
Old 01-25-2013, 10:33 PM   #18
pat in Santa Cruz
pat in Santa Cruz's Avatar
if the other possibilities not already suggested do not pay off, shoes that are not exactly centered feel spongy. Also, if one wheel or more is adjusted more loose than the others, the pedal will feel spongy too.
pat in Santa Cruz is offline   Reply With Quote
Old 01-26-2013, 08:26 AM   #19
Keith True
Keith True's Avatar
Try going through the adjustment procedure without that board.See what you have then.
Keith True is offline   Reply With Quote
Old 01-26-2013, 09:34 AM   #20
BrianBurkert
BrianBurkert's Avatar
The newly rebuilt brakes were spongy on my roadster. I ran it a little while and then completely readjusted. Now they are firm.
I don't bother with the 60-40 bit. I recall the modern thinking is you don't want the rears to lock up first, as it causes loss of stability (i.e. back end breaks loose and the car tries to spin around).
BrianBurkert is offline   Reply With Quote
