01-13-2013, 12:29 PM | #1 |
ampmeter not marked what terminal is positve
i am wiring terminal box to dash and my ampmeter does not
have marking - or + ? any help here thanks fredski |
01-13-2013, 12:38 PM | #2 |
Re: ampmeter not marked what terminal is positve
this should help as long as you have a stock 6v pos ground system. pos would be the y/b wire on the right side of the meter
01-13-2013, 12:54 PM | #3 |
car stock + 6 volt positve. have diagram and magnifer but was not sure
of direction of diagram, looking at face of ampmeter right side post is positive. this is what you mean. in other words post facing pass door. thanks for help fred |
01-13-2013, 12:56 PM | #4 |
Wire it in turn on the headlamps and see which way the needle moves. If it moves to the right swap the wires.
01-13-2013, 12:57 PM | #5 |
Take a guess, much better odds than the lottery. Hook up the wires. Don't reinstall the instrument panel. Turn on the lights to be sure the ampmeter shows negative. Correct if necessary. Reinstall instrument panel.
Charlie Stephens |
01-13-2013, 01:05 PM | #6 | |
will try use 6 v volt charger in its place, should work, did so to see if new light wiring harness was hooked up properly. fred |
01-13-2013, 01:17 PM | #7 |
01-13-2013, 06:23 PM | #8 |
Dog here, WHOA!
Got me coufused with which side is WHICH???~~~~~~~~~Hey! who's driving??? I think it's my turn, Oh! I forgot, we won't have the wheels & new COKER CLASSICS (blackwalls) 'til tomorrow. Buster T.
01-13-2013, 06:47 PM | #9 |
Hey buster T, Parker here
I think you got dizzy chasing your tail, i know i did chillin out |
01-13-2013, 11:10 PM | #10 |
I asked the same question a few months ago. Followed the image diagram Mitch posted and I was set.
Learning the A at the Ford Barn, so I can pass it down do the next generation. |
01-14-2013, 09:58 AM | #11 |
01-14-2013, 11:34 AM | #12 |
There is a good easy to follow wiring diagram on page 92 of the new Brattons catalog. Some of the repro replacement ammeters are model T. The model T was negative ground. The late model T ammeter fits the model A instrument panel but the wires must be reversed if used on the positive ground model A.
01-14-2013, 02:47 PM | #13 |
Had the same question earlier but with some thought and reading the instructions again, I noticed the words charging post and discharging posts. Tried things that way and it was right the first try.
01-14-2013, 08:50 PM | #14 |
have wired so needle goes to -neg on gage with light switch on.
no battery yet but used my battery charger for power. thanks everybody for helping out, fred |
01-15-2013, 08:54 AM | #15 |
Fred,
This is "For Your Information", if your ammeter is a reproduction, check the lugs for tightness, it may have to be disassembled to do so. Even though the wires are tight on the outside the lugs can be loose at the meter's movement which causes heat. I've found several like this. |
01-15-2013, 09:03 AM | #16 | |
01-15-2013, 11:26 AM | #17 |
I'm installing one this weekend on my dad's Model A. His is a 12v negative ground system that cannot use the regular Model A wiring diagram. Anyone have a universal wiring diagram for a 12v negative ground system? Thanks in advance.
1929 Model A 1992 Galant VR4 474/1000 2007 Prius 54mpg |
01-15-2013, 11:35 AM | #18 |
Connect the battery cables hegative ground. Reverse the connections at the ammeter and the coil. You will need to either use a ballast resistor at the coil or use a 3.0 OHM coil.
01-15-2013, 01:10 PM | #19 |
If all you're doing is the ammeter, install and note the wires whilst checking, you may have to swap them for the meter to register correctly.
01-15-2013, 03:05 PM | #20 |
Hello guys, to clarify, the wiring in my dad's Model A resembles nothing like a Model A. There was not an ammeter in place before, and there are no wires for one. Using the regular Model A diagram is not using for this application.
