#1 |
I would assume that you would want minimal axle shaft end play. What is recommended maximum?
I understand ring gear to pinion back lash, but do not know how it is checked on the Model A rear end. Any ideas? Can someone that has done this figure out a way to equate it as degrees of rotation on the drive shaft while holding the ring gear stationary?
Uncle Bud says "too soon old, too late smart!" |
