12-26-2012, 03:12 PM | #1 |
re-torque heads
hey guys, im fixing to start my fresh eab in my 50 f1,
i was wondering if i should re-torque the heads while still hot, warm or cold ? there stock cast iron heads. thanks |
12-26-2012, 03:50 PM | #2 |
Re: re-torque heads
retorque cold, keep retorquing every week or so if you do a lot of driving till the bolts quit moving
12-26-2012, 07:13 PM | #3 |
Re: re-torque heads
A local engine builder taught me a trick which I'll pass along. When you torque your heads, go over them three (3) times when you reach the maximum torque you'll be using. It's amazing - at least to me - how many of the bolts will move on the second or third pass without increasing the torque setting on the torque wrench. Maybe I'm the only one on the 'Barn that didn't know this but thought I'd pass it on. FWIW
Definitely re-torque when cold, after one or more heat cycles. |
12-26-2012, 07:21 PM | #4 |
Re: re-torque heads
On the cast iron heads I always retorque the heads hot after you've run it 15-20 min. at 15-1800 RPM. On the aluminum heads retorque after thay have cooled off. Walt
12-26-2012, 10:16 PM | #5 |
Re: re-torque heads
thanks guys.
01-05-2013, 02:33 PM | #6 |
Re: re-torque heads
01-05-2013, 04:57 PM | #7 |
Re: re-torque heads
A teacher I had in mechanic school used to tell us to give them a tap with a hammer after tourquing to relieve the binding stress on face of bolt.The odd bolt will give an extra 1/8 or so on a tourque recheck...
01-05-2013, 07:54 PM | #8 |
Re: re-torque heads
yes Blu Dice, for real, i torque the 49 -53 head bolts to 70 foot pounds, you keep checking the torque till one day the bolts wont turn any more when pulled to specified torque, quality engine builders do use a torque wrench, i use one that clicks when the determined torque is reached, now do you understand?
01-06-2013, 12:32 AM | #9 |
Re: re-torque heads
I never torque more than 50 ft. lbs. No need for any more.
01-06-2013, 07:02 AM | #10 |
Re: re-torque heads
10-4 on that!!
01-06-2013, 07:48 AM | #11 |
Re: re-torque heads
you ever wounder why when they left the factory they were never touched . i dont think they torqued them over & over at the factory . but i agree with henry kokmo torque 3 times following the sequence in the manual
01-06-2013, 09:12 AM | #12 |
Re: re-torque heads
Do you think a re-torque would have been done when the car went in for it's first service? Did they have a set service interval back then??
Mart. |
01-06-2013, 09:52 AM | #13 | |
Re: re-torque heads
01-06-2013, 10:21 AM | #14 |
Re: re-torque heads
My Daddy was the Service Manager at a Ford dealership when I was a young boy. The introduction of the new models was a very big deal back in those days. I remember they would hide the new cars and prepare them "after-hours" until the announcment day. This is my first memory of watching the mechanics perform the "new car inspections". I can say with 100% certainty that the head fasterers were checked, with a beam-type torque wrench, on all the new cars at, at least, one Ford dealership.
01-06-2013, 10:27 AM | #15 |
Re: re-torque heads
motors manual 1935 to 1953, if you really want ot get picky the book says torque from #65 to #70, i torque my engines to #70 to help reduce the chance of the head gaskets weeping between retorqing and yes the new cars were taken back to the dealership at regular intervals for for service, and the head bolts were retorqued, in fact they were advised to bring them back several times for check ups. i think its time for you to buy a few books, JWL's, Ol rons , Les Andrews, a motors manual, 1935 to 1953, then maybe you wont be so confused, i dont want to argue with you on this, so i will not respond to any more of your posts, do some research then start on your engine, is a hell of a lot of fun building them
01-06-2013, 10:30 AM | #16 |
Re: re-torque heads
Don't you just love the Flathead??
01-06-2013, 10:39 AM | #17 |
Re: re-torque heads
Blu Dice:
You get a lot of info here from both end of the thought process So if you bunch it all together and split it down the center you should be all right. It is like you said it's not Rocket science and these flathead are mort forgiving. So don't over think the problem / just get it together and enjoy the ride... JMHO |
01-06-2013, 11:25 AM | #18 |
Re: re-torque heads
flatjack9, there is some confusion on head torque, the 1935 to 1948 flatheads recomended torque is 50 to 60 pounds, and the aluminum heads require s diferent torque nothing is written in stone, use what works for you, and its like Bill Wzorek says, the flathead engine is very forgiving, they have survived many years with a lot of beginners working on them, he also said "just get it together and enjoy the ride", and im all for that
01-06-2013, 11:31 AM | #19 | |
Re: re-torque heads
Thanks again for all comments. |
01-06-2013, 07:12 PM | #20 |
Re: re-torque heads
There should be no seepage at 65#. I would suggest your heads may need removing and having a light skim to make them dead flat. Or a can of Bars Leaks!
