Go Back   The Ford Barn > The Swap Meet > For Sale > Model-A
Old 12-25-2012, 05:11 AM   #1
LizardsA
LizardsA's Avatar
Default Help needed with a Zenith B carburetor
City: Johannesburg
State: South Africa
I took the float and needle and seat out of my 1930 Sport Coupe Zenith 'B' carburettor, and when I put it all back together, I can't remember which way the spring goes to hold the float up. Now I have fuel leaking out of the carburettor - can anyone shed some light on which way the spring goes please?
Here are some pictures of how it is assembled right now:
LizardsA is offline   Reply With Quote
Old 12-25-2012, 01:52 PM   #2
ctlikon0712
ctlikon0712's Avatar
Default Re: Help needed with a Zenith B carburetor
Don' take this as gospel, but it looks like that spring arm that is in the lower right of the picture should go underneath the pivot rod and should be located on the backside right behind the nub there on the float arm..... JMHO
Wanted: Simmons Super Power Head
Craig Likon 1931 150B
ctlikon0712 is offline   Reply With Quote
Old 12-25-2012, 02:09 PM   #3
Brian T
Brian T's Avatar
Hello and greetings,
My understanding is that the spring and baffle are only needed if you are using a fuel pump, if gravity feed then you can leave it off, I could not find a good picture that shows the correct placement of the spring,
Post this on the discussion section, there are many folks there familiar with the B carb.
Regards Brian T.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 12-25-2012, 04:20 PM   #4
darrylkmc
darrylkmc's Avatar
Merry Christmas from Alaska,
Joop was kind enough to post a link to this post on the Fordbarn Model A discussion forum, here is a link to that post:
https://www.fordbarn.com/forum/showthread.php?t=92755
I do not use this spring on the Model B carburetor on my Model A. The pressure of the fuel in the bowl against the float is what stops the fuel from flowing. Seems to me you have one of two problems:
Either your needle and seat are not sealing due to wear or dirt
or
Your float is set to high and the fuel is overflowing.
Here are a couple of links to Fordgarage which show details of the Model B Carburetor, thanks to Vince Falter.
http://www.fordgarage.com/pages/bcarbuppercastings.htm
http://www.fordgarage.com/pages/bcarbdiagram.htm
Hope this helps, and let us know on the discussion board.
Darryl in Fairbanks
darrylkmc is offline   Reply With Quote
Old 12-26-2012, 12:31 AM   #5
columbiA
On both my B engined A,s,I dont use the spring on float pin.
columbiA is offline   Reply With Quote
Old 12-26-2012, 09:38 AM   #6
Banky
I do that kind of shit all the time! Now I take quick cell phone picts of stuff I'm taking apart for reference. A little late, but good for your next endeavor.
Banky is offline   Reply With Quote
