Old 12-23-2012, 08:56 PM   #1
Kaptain Karl
Default clutch and gear problems
I have just recently aquired a 1929 fordor that has been sitting for 40 years in a garage. I got it to start this past weekend and when I went to shift, the car would not go into gear. The clutch would go in with some tension like it should, but when I tried to put the car in any gear the shifter would just grind and not even slow down the gears. The Fluid was low so I added some. The car will shift into gear when it is off. If I try to start the car with it in gear AND the clutch in, the car rolls forward while trying to start. Could the gears be rusted together, and if so, can I jar them apart. Any help would be great. Thanks, Kaptain
Kaptain Karl is offline   Reply With Quote
Old 12-23-2012, 09:01 PM   #2
Steam Engine Pete
Steam Engine Pete's Avatar
Default Re: clutch and gear problems
Kaptain,
The clutch disc is stuck to either the pressure plate or the flywheel. Should come apart to fix it correctly but I have had some luck with starting the vehicle(in a clear area) in gear. Hold the clutch pedal in while you are moving and apply the brakes a few times. May be able to knock it loose.
Pete
Steam Engine Pete is offline   Reply With Quote
Old 12-23-2012, 09:06 PM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
"Probably" metal fibers in disc lining rusted to smooth flywheel surface, quite common!
Take out the floorboards & remove bell housing inspection cover. With a long skinny brass drift & a hammer, tap on the clutch disc center hub where it slides on the trans input shaft. Hold down on the clutch pedal while hittin' it. Bill W.
(Try Pete's way first, it'll be easier if it works)
"THE ASSISTANT GURU OF STUFF"
Old 12-23-2012, 09:16 PM   #4
Kaptain Karl
Thanks for the rapid responses. I'll be trying those things on Christmas morning since I have to work on Mon. I'll be praying for that Christmas miracle.
Old 12-23-2012, 09:24 PM   #5
BILL WILLIAMSON
Karl,
This is the only thing I do QUICK, except for f**ts & sneezes! Bill W.
Old 12-23-2012, 09:25 PM   #6
Steam Engine Pete
Wish I could come and help on Christmas morning. I have to go to the in-laws for the 967th time for Christmas day. Would rather work on an A.
My in-laws are great, I just don't like sitting in the house all day.
Pete
Old 12-23-2012, 09:32 PM   #7
Fred K-OR
Fred K-OR's Avatar
Another way similar to Pete's would be to put it in high gear, hook on to it with a tow vehicle, push in the clutch and try to pull it. Do not hook on to the front axle in the middle of it-will bend the axle. Put it around the frame. Good luck and hope Santa gives you A Christmas present.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-23-2012, 09:43 PM   #8
Kaptain Karl
My Driveway is a hill, so I was going to tow it up the hill and coast down in first or second with the clutch pedal in and tap the brakes and see what happens
Old 12-23-2012, 09:54 PM   #9
BILL WILLIAMSON
Karl,
Remember, you gotta' be driving with the motor in locked up LOW, then hit the brakes hard a few times. Don't take the wife with you, they don't understand Krazy stuff like that!! (SCREAM!!) Bill W.
Old 12-23-2012, 10:00 PM   #10
Steam Engine Pete
I am from Eastern North Dakota where hills are foreign to us. Just make sure you can stop the car.
Applying the brakes while coasting down a hill will reduce the force applied to make the clutch release. If I was certain the brakes could stop the car I would drive it up the hill with the clutch pedal depressed and intermittently apply the brakes to jar it loose.
Pete
Old 12-23-2012, 10:01 PM   #11
Kaptain Karl
Hopefully she'll still be sleeping and the kids will be in a present coma and coming down from their sugar high. I'll be needing fresh air away from the family.
Old 12-23-2012, 10:03 PM   #12
bobf
I think you've got a multidisc clutch...take a look in the inspection plate.... Bob F in cold Ontario!!
bobf is offline   Reply With Quote
Old 12-23-2012, 10:03 PM   #13
Kaptain Karl
I have 16 acres and 1000 ft drive way with lots of fields to get into. Not worried about stopping
Old 12-23-2012, 10:05 PM   #14
Kaptain Karl
Whats a multi disc clutch?
Old 12-23-2012, 10:06 PM   #15
BILL WILLIAMSON
Karl,
Don't sleep in the car, or you'll be SOOOOOORY!! bILL w.
Old 12-24-2012, 01:48 AM   #16
700rpm
700rpm's Avatar
They were used in early 28, and were discontinued because the dust material from clutch wear was clogging up the discs and making the clutch inoperable. Maybe someone here can post a picture that will explain how you can tell looking through the inspection hole. If the inspection plate has no louvers in it, you very likely have a multiple disc clutch. The date on your firewall might also give you a clue. The multiple disc clutch was dropped in about November of 1928.
Ray Horton, Portland, OR
Old 12-24-2012, 05:13 AM   #17
Tom Wesenberg
Tom Wesenberg's Avatar
The single plate was introduced in November 1928, so this 29 should be a single plate clutch and flywheel.
The multiplate inspection cover is WIDER than it is tall, and the single plate cover (as shown on the right two covers) is TALLER than it is wide.
The AA clutch housing cover is the same width and height.
Old 12-24-2012, 10:01 AM   #18
Marco Tahtaras
Marco Tahtaras's Avatar
We went through the stuck clutch issue about six months ago. Similarly the car had been parked for 40+ years.
What we did was jack the rear end up and placed it on a pair of stable jack stands. We started the engine with the trans in first so it would be tougher to kill the engine. I brought the engine speed up above a fast idle and applied the brakes until the engine would drag down and released the brakes. I repeated this several times being a little more abrupt with the brake pedal until I got a "bang" as the clutch popped free. I then partially engaged the clutch while still holding the brakes on to slip the clutch a bit.
We put the car back down to do a test drive and it was stuck again! So back up on the stands it went for a repeat which of course was much easier this time, and I slipped the clutch a little more. This time we shut it down for a minute and then retested while still on the stands and all was fine so we put it down and drove it around a bit.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 12-24-2012, 09:15 PM   #19
Kaptain Karl
Thank you for everyones input. Iwill be trying these method soon and hopefully I can free up the gears. I really liked the idea of the car on jack stands. Sounds a little more safe and in control
Old 12-24-2012, 10:01 PM   #20
BILL WILLIAMSON
Dog here,
Please let us know, we're waiting with "BAITED BREATH"! (I stole that line from someone here! I don't know how to spel playgerize) Buster T.
