12-16-2012, 10:23 PM | #1 |
1928-29 front bumber brackets
Can you tell me from the pictures if I have the right front bumber barckets for a 1928?
12-16-2012, 11:04 PM | #2 |
Re: 1928-29 front bumber brackets
Yes, they are original '28-29 brackets but have been bent somewhat from collision damage.
http://www.abarnyard.com/ |
12-17-2012, 12:58 AM | #3 |
So the outer ends should not curl back at all?
12-17-2012, 02:00 AM | #4 |
The bumper attaches at the clamp just at the point where it [ the bumper bar] starts to curve in. The brackets therefore appear to slightly curve back.
Your brackets appear original,bearing the C stamp; mine have a D. |
12-17-2012, 11:02 AM | #5 |
I can't be sure but believe this example is bent but only slightly. It must be perfectly straight coming out from the frame. The outer end looks to me like it should be 1/4"-3/8" closer to the center of the car. I could be wrong but it at least gives you an idea.
12-17-2012, 09:22 PM | #6 |
I also measured the brackets and a straight line from one end to the other end of the bracket is 18". |
