Old 12-16-2012, 07:43 PM   #1
Lembomw
Lembomw's Avatar
Default Weber Carb Set-Up
Hi, I am rebuilding my 30’ Tudor and had a touring engine built for it. It has a Weber downdraft carb. I am going to install an in-line filter, fuel pump and a low pressure regulator. I understand that some just run the gas from the fuel bowl to the Weber and depend on gravity but I do not want to take any chances. Does anyone have a similar set-up and can send me pictures of how the fuel line, filter, pump and regulator were run from the firewall to the carb. I assume that the glass fuel bowl can be eliminated (one less thing to leak).
As always, thank you very much for your assistance;
Mark
Lembomw is offline   Reply With Quote
