Old 12-14-2012, 01:34 PM   #1
bogiediver
bogiediver's Avatar
Default DRAFT - Front End Rebuild Outline
After spending a fair amount of time (probably more than I should have...) reviewing various threads on front end work and not finding a 'guideline' (for lack of a better term) to follow if attempting to inspect, and rebuild as necessary, all the components of the front end - I put together an outline starting at the radius ball at the trans housing and working forward and out to the wheels, based on what I read in the various threads...
Now - I'm not sure I even qualify as a shade-tree mechanic, much less someone who actually knows what he's talking about; but I thought this might be a starting point for the true experts to chime in to possibly modify the draft to come up with something a newbie could use as a reasonable guide.
I'm willing to compile the info, so if you're interested...
FWIW
PDF will be the latest version after acknowledging input from contributors.
- bogie
'31 (Mostly) Roadster
Last edited by bogiediver; 12-18-2012 at 12:53 PM. Reason: added note about PDF and PDF replaced with latest version
bogiediver is offline   Reply With Quote
